exhaust ratting!!
Old Feb 27, 2008 | 01:25 PM
DoHcV-tEc's Avatar
Default exhaust ratting!!
Welli have a 95 integra gsr, just put in a new donut and took off the heat shell and its rattles and idea what it could be? thanks.
Old Feb 27, 2008 | 02:14 PM
iH8RICERZ's Avatar
Default Re: exhaust ratting!! (DoHcV-tEc)
It could be your other heat shields or you might just have to tighten your exhaust bolts a little more. I mention both because I've had rattles before due to these two things.
Old Feb 27, 2008 | 07:41 PM
DoHcV-tEc's Avatar
Default Re: exhaust ratting!! (iH8RICERZ)
which other heat shell how any is there?
Old Feb 28, 2008 | 09:02 PM
DoHcV-tEc's Avatar
anyone?
Old Feb 29, 2008 | 09:08 AM
iH8RICERZ's Avatar
There are other heat shields besides the one around the cat. My latest rattle was from one of the heat shields by the "s" shaped exhaust pipe. It was rubbing against the heat shield so I just had to bend it back a little bit.
Old Feb 29, 2008 | 09:10 AM
90 2g GS's Avatar
* B A N N E D *
Get down there and look at whats making noise
Old Feb 29, 2008 | 10:01 AM
mormonboy's Avatar
Default Re: exhaust ratting!! (90 2g GS)
heatshields above the cat.
Old Feb 29, 2008 | 12:22 PM
dc2415's Avatar
could be a bad resonator, but that causes more of a pinging sound at idle
Old Feb 29, 2008 | 12:33 PM
DoHcV-tEc's Avatar
Default Re: exhaust ratting!! (dc2415)
na it just rattle at 3rpm idk i already took off one heat shell
Old Feb 29, 2008 | 12:46 PM
northemt88's Avatar
there are 2 on your header, and heat shields running the length of your exhaust
Old Feb 29, 2008 | 09:21 PM
DoHcV-tEc's Avatar
Default Re: exhaust ratting!! (northemt88)
so theres one in cat right?
Old Mar 1, 2008 | 01:45 AM
stealth50k's Avatar
I have the gsr header also, its the header. I heard theres 2 pipes that are going down to the exhaust and those are loose. Some people i heard just spot weld them. Mine rattles to at 3k rpm but haven't had any time to weld anything lately.
Old Mar 1, 2008 | 08:17 PM
DoHcV-tEc's Avatar
Default Re: (stealth50k)
Yea probably it might be the header any more ideas?
Old Mar 1, 2008 | 08:33 PM
infamouskillas's Avatar
Default Re: (DoHcV-tEc)
not sure if i understand what ur talkin about but if i do, it could be loose or rusted clamps to hold piping together...or hangers that are loose, rusted or just simply not on right...sorry if this doesn't help
Nelson_
Apr 13, 2016 04:40 AM
SpeedDemonRex
22
Feb 3, 2014 01:16 PM
Itr001
Oct 28, 2005 07:24 AM
jayare05
11
Nov 23, 2004 08:18 PM
bad93ex
Sep 28, 2002 02:19 PM
