new crank for all motor?
Old Feb 27, 2008 | 11:51 AM
integra gsr96's Avatar
Default question about crank and nos. help?
i was wondering if i would need a new crank if im doing a allmotor build? also another question im building my car for high compression and im going to spray nitrous in it will it hurt the motor in anyway? can i spray 50 or 75 shot?
Modified by integra gsr96 at 1:05 PM 2/27/2008
Old Feb 27, 2008 | 12:15 PM
Combustion Contraption's Avatar
You need to be more specific.
What engine?
Old Feb 27, 2008 | 02:26 PM
lohatch's Avatar
Default Re: question about crank and nos. help? (integra gsr96)
unless you are looking to increase the stroke beyond what you can achieve with an OEM crank you will not need to purchase a different one.
and if the engine is tuned properly and the right components are used you will have no problems with a small shot.
i noticed you are in MN. i am as well and jordan from consummate tuning is located in owatonna. he can help you with your tuning needs.
Old Feb 28, 2008 | 08:19 PM
Default Re: (Combustion Contraption)
gsr b18c1
Old Feb 28, 2008 | 08:25 PM
AccordSleeperZzZ's Avatar
Default Re: (integra gsr96)
unless you're planning on stroking the motor, i'd say no. the stock honda cranks are pretty damn good. at most, take the stock one to a machineshop and have them make sure everything's in spec.
and no, if you tune it right, a small shot like - you should be fine.
good luck.
Old Feb 29, 2008 | 04:10 PM
Default Re: (AccordSleeperZzZ)
thanks for the tip.
hoffdaddy
Jan 26, 2015 08:40 AM
goldhatch94
May 18, 2009 01:14 PM
civiconfire
Oct 31, 2007 12:44 PM
Guru Designs
Jul 2, 2004 11:10 AM
zojirushi
Nov 22, 2001 07:21 PM
