filling/sealing holes in trunk pan..
Old Feb 27, 2008 | 11:33 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default filling/sealing holes in trunk pan..
im removing a hitch in my car, and its going to leave 4 good size holes in the trunk pan under the spare tire. im sure water wont come up inside, but ide like to seal it off, for whatever moisture, and dust.
what kind of product could i use to seal it? maybe household caulking?
Old Feb 27, 2008 | 12:13 PM
wiZCo's Avatar
Stouts 'n' Scotch
Use caulk or 3M Window Sealant.
Old Feb 27, 2008 | 12:53 PM
7andaswitchblade's Avatar
you might want to consider taking a look at pep boys, or a similar store, and see if you can find some rubber grommets to stick in the holes, and then seal the grommets in to place, depending on how big the holes are.
Old Feb 27, 2008 | 05:57 PM
iam7head's Avatar
Default Re: (7andaswitchblade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7andaswitchblade &raquo;</TD></TR><TR><TD CLASS="quote">you might want to consider taking a look at pep boys, or a similar store, and see if you can find some rubber grommets to stick in the holes, and then seal the grommets in to place, depending on how big the holes are.</TD></TR></TABLE>
honda sells one actually, search under s2000 trunk
Old Feb 27, 2008 | 09:22 PM
Built B16A's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
honda sells one actually, search under s2000 trunk</TD></TR></TABLE>
yeah, can you elaborate alittle more on that.. i searched "trunk" and "trunk plug" both in open searches, and in s2000 forum and got no results anywhere close to my problem.
and i have 4 holes.. about 3/8 each.. small bolts..
Old Feb 28, 2008 | 09:46 PM
iam7head's Avatar
Default Re: (Built B16A)
i think they are soft rubber plug, there's two of those in my s2k trunk pan.
go search under majestic honda or in the s2k manual
Old Feb 28, 2008 | 09:53 PM
Built B16A's Avatar
Default Re: filling/sealing holes in trunk pan.. (Built B16A)
im lost.. any help?
tekniq
Jul 8, 2008 09:54 PM
CBURKE
Welding / Fabrication
Jun 12, 2006 01:31 PM
Elbowpunk
Nov 12, 2005 07:09 AM
db8geezer
Oct 25, 2005 04:20 AM
AMG
Oct 5, 2005 01:15 AM
