96-98 coupe tails the same as 99-00?
Old Feb 27, 2008 | 09:28 AM
blinger's Avatar
Default 96-98 coupe tails the same as 99-00?
tried searching but i guess my keywords suck
Old Feb 27, 2008 | 09:49 AM
NOFX's Avatar
H-T White Ops
Default Re: 96-98 coupe tails the same as 99-00? (blinger)
I'm confused on what exactly you're needing to know.
Are they they same shape?
Yes.
Do they fit on the same cars?
Yes.
Do they take the same bulbs?
All but the turn signal.
Are the harnesses the same?
The outer harnesses are different for the turn signal.
Are they the same?
Of course not. The '99-'00 coupe taillights are clear/white all the way across, while the '96-'98s are amber with a clear/white spot for the reverse light. And no, the red/clear ones aren't just for the Si.
Don't take any of this to be towards just you. This is for others who might find it too.
Old Feb 27, 2008 | 09:57 AM
IIXtremeHansen's Avatar
http://www.clubcivic.com/board...rence
They fit, just diffrent color.
Old Feb 27, 2008 | 10:09 AM
NOFX's Avatar
H-T White Ops
Default Re: 96-98 coupe tails the same as 99-00? (Dickies_n_FlipFlops)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">http://www.clubcivic.com/board...rence
They fit, just diffrent color.</TD></TR></TABLE>
That link doesn't take into consideration all body styles.
Unfortunately it also encourages people to pay attention to the inside of the headlights too, which leads people to think that the headlights are closer in shape than they actually are. There are also other interior and exterior differences, not to mention mechanical differences.
I really wish that thread would get edited to better cover the differences. Especially since it's being linked.
Old Feb 27, 2008 | 11:12 AM
blinger's Avatar
Default Re: 96-98 coupe tails the same as 99-00? (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">I'm confused on what exactly you're needing to know.
Yes.
Yes.
Are they the same?
Don't take any of this to be towards just you. This is for others who might find it too.</TD></TR></TABLE>
I just need to know if I buy a set of 99-00 tail lights, will they work with my 96 coupe. different bulbs aren't a problem, but what will I have to do with the harness?
Old Feb 27, 2008 | 11:26 AM
SOHC4life 96's Avatar
Just use the harness that you have on you car right now. That is what I did and it worked just fine.
Old Feb 27, 2008 | 11:33 AM
00CivicGirl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">. And no, the red/clear ones aren't just for the Si.
argh I hate when everyone says wow you go SI tails..I say no i have stock tails
Old Feb 27, 2008 | 08:22 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">I just need to know if I buy a set of 99-00 tail lights, will they work with my 96 coupe. different bulbs aren't a problem, but what will I have to do with the harness?</TD></TR></TABLE>
It's easiest if you just use the harness that goes with the taillights. If you use the one for the different year range, it coudl be more difficult to find amber turn signals. If you use clear bulbs for the turn signals, you run the risk of being pulled over.
Old Feb 27, 2008 | 08:23 PM
ke98248's Avatar
Default Re: 96-98 coupe tails the same as 99-00? (00CivicGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00CivicGirl &raquo;</TD></TR><TR><TD CLASS="quote">
argh I hate when everyone says wow you go SI tails..I say no i have stock tails </TD></TR></TABLE>
Exactly -- they came on the EX AS WELL AS the Si models
99-00 ex/si tail lights
96-98 ex tail lights
Old Feb 27, 2008 | 08:48 PM
NOFX's Avatar
H-T White Ops
Default Re: 96-98 coupe tails the same as 99-00? (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Exactly -- they came on the EX AS WELL AS the Si models
[http://www.geocities.com/ke98248/4159-1999-Honda-Civic.jpg[/img]
[http://www.snapdrive.net/files/7978/97civicexcoupe.jpg[/img]</TD></TR></TABLE>
Actually, those would be '99-'00 DX coupe, EX coupe, HX coupe and Si coupe taillights and then '96-'98 DX coupe, EX coupe and HX coupe taillights.
They're not just Si and they're not just for EX and Si.
Here are some photos to accompany.
1996-1998 DX coupe
1996-1998 EX coupe
1996-1998 HX coupe
1999-2000 DX coupe
1999-2000 EX coupe
1999-2000 HX coupe
1999-2000 Si coupe
Modified by NOFX at 10:12 PM 2/27/2008
Championship
Jul 18, 2011 08:13 PM
jdmsohc2nr
Lighting
Jan 5, 2008 06:30 PM
young noob
Oct 19, 2005 01:17 PM
93TurboSi
11
Jul 12, 2005 03:33 PM
eug_34
Nov 13, 2004 05:40 PM
