ecu/egr system h22a ek swap help
Old Feb 27, 2008 | 12:19 AM
h22hatch88's Avatar
Default ecu/egr system h22a ek swap help
ok i have an h22a in a 1998 ek, i have a p13 ecu with an obd2 to obd1 conversion. my egr isn't hooked up at all and i may be missing the vacuum control and the solenoid for it. well i read that if you put a p28 ecu in it the egr wont even throw a code like it doesn't even look for it and car will run fine. my question is if i do this will i have to change anything with my wiring or change anything at all, or will it just be a literal swap out of ecus and everything is fine? any info or opinions are thanked in advance.
Old Feb 27, 2008 | 01:35 AM
86elco's Avatar
Default Re: ecu/egr system h22a ek swap help (h22hatch88)
As far as the wiring goes it should be just plug it in and go,, you could just keep the p13 though the egr CEL is a soft code and wont hender the performance at all just turns the light on ,,, thats how i have mine until I can get some type of other ecu like hondata or crome
Modified by 86elco at 2:46 AM 2/27/2008
yexer7
Sep 21, 2015 06:27 AM
majdi
Engine Management and Tuning
18
Jan 12, 2011 02:30 AM
sgallant44
Jul 3, 2009 10:42 AM
NY93CivicEx
Jul 12, 2005 10:33 PM
95accordh22a
Nov 3, 2004 07:26 PM
