1988 Honda Civic Hatch DX Auto 1.5L Dual Point
Old Feb 26, 2008 | 09:29 PM
pogopunk's Avatar
Default 1988 Honda Civic Hatch DX Auto 1.5L Dual Point
Im getting a code 8 from my ecu. check engine light is on, when i start up my car and give it gas it chokes up and dies out.
I just changed my thortle body and dizzy and still have the same problems checked all my vac hoses nothing out of place checked fuel presure and it's fine.
After changing them car starts up stays on for no more then a min and just dies on its own and my check engine light is still on and flashing me code 8.
I can keep the car on if i tap on the throttle cable gently but if i punch it it chokes and also when im gently pressin on the cable it kinda boggs out and back fires adjust the dizzy as well.
Only thing out of everything I have not checked is the Timing Belt.
hmm also im leaking oil from my oil pan but check dip stick and shows it's levels good but when low I put some oil.
Can anyone help me out here ?
I've been trying to get this car to work for 3 weeks ...
Old Feb 26, 2008 | 09:42 PM
DailyDriverCivic's Avatar
Default Re: 1988 Honda Civic Hatch DX Auto 1.5L Dual Point (pogopunk)
Code 8 = TDC - top dead centre sensor, which is in the distributor. Either the sensor in the distributor, the wiring, or the ECU is bad.
Old Feb 26, 2008 | 09:53 PM
pogopunk's Avatar
Default Re: 1988 Honda Civic Hatch DX Auto 1.5L Dual Point (DailyDriverCivic)
my wiring harness is spliced up the @$$ alot of mickey mouse wires and wires touching harness connection to the dizzy.
Old Feb 26, 2008 | 10:04 PM
pogopunk's Avatar
any sugg abouts where i can find myself a harness .. ?? and how much they range from ??
so my wiring could just be the problem of the bogging also ?? or should i check my timing for that ?
Old Feb 26, 2008 | 11:18 PM
pandarex's Avatar
i'd just check your wiring. if the wiring is good, its most likely your dizzy.
your best bet for buying a harness would be a junkyard
Old Feb 27, 2008 | 12:25 AM
pogopunk's Avatar
Default Re: 1988 Honda Civic Hatch DX Auto 1.5L Dual Point (pandarex)
I believe my wire harness is crap there are wires cut everywhere dangling in the air. Wire harness at a junkyard go for about 40 $ ??
Well thanks for the help guys. I'm gonna take a look at my Wires again and see if i can do anything to help fix all the loose wires everywhere. or if not forget about the hassle just go buy another one ...
oh yeah also lol on my harness on the intake manifold from the map sensor they spliced the wire to try and create a ground and then groundned to the intake manifold bolt.
Old Feb 27, 2008 | 08:12 AM
pogopunk's Avatar
I bought myself a brand new harness and getting another dizzy by friday if those dont work im gonna rule out my dizzy and try to see whats up with my ECU also should i have disconnected the battery before installing the new dizzy ?? i believe i had the negative wire disconnected only.
Old Feb 28, 2008 | 10:56 PM
pogopunk's Avatar
i can rule out the ecu picked one up for 15 bux cant find a wireharness so should i change my dizzy again ??
Old Mar 7, 2008 | 03:20 PM
pogopunk's Avatar
so i changed my dizzy .. changed my wire harness changed my ecu and still have the same problems but now after changing my wire harness i get a code 8 still and code 14 now.
14 IAC (EACV) - idle air control valve
what is this ?? and where is it located .. ??? did i switch some wires around ?
can someone please help me before i pull my hair out
macMFNcheese
Honda CR-V & Element
Aug 18, 2020 01:38 PM
Daniel Mata
Honda Civic (2001 - 2005)
Apr 7, 2014 09:18 PM
Crowinghen
17
May 24, 2013 06:44 AM
j0hn-0h
Jan 22, 2006 02:28 PM
xvracing
Dec 10, 2003 08:04 AM
