Tire Air Pressure
I know I will get flamed for this but here goes anyway. I'm just wondering what the optimal air pressure on my tires is. I have Kumoh Ecsta (AST I think) and I looked at the tires but could not figure our what all the different numbers were. What should I look for?
Stickied at the top of this forum, where you'd have to be absolutely clueless to miss it, is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING »</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">Tires FAQ</FONT>
What air pressure should I use in my tires?
As a general rule, regardless of wheel or tire size or type, the best place to start is with the pressure recommended for your CAR, as shown in your owner's manual and on your car either on the door jamb or glove compartment door. Measure the pressure when the car has been sitting for several hours out of the sun, at the outside temperature at which the car will be used. Adjust from there in 2 psi increments as needed, based on tire wear and your preference for handling and/or ride comfort.
Do NOT set the pressure to the maximum pressure indicated on the sidewall of your tire.
It says:
Ops, sorry about that. So the recommended tire pressure for my car then, alright. I'll check that out. Anyone know what it is for Acura Integra's off the top of their heads? (1999)
