what is the best way to remove header bolts without breaking them
Old Feb 26, 2008 | 01:19 PM
korndog's Avatar
Default what is the best way to remove header bolts without breaking them
as the title says wat is the best way to remove the bolts without snapping them.
I have heard all kind of different methods from letting the car run for a little while to the bolts are hot. Some say wait untill the car is cold. Some say soak the bolts everyday for a week strait with wd40
Whats the best way what has worked for everyone else successfully?
Thanks
Old Feb 26, 2008 | 02:42 PM
gsr dood's Avatar
Default Re: what is the best way to remove header bolts without breaking them (korndog)
I only take em out when that car is warm. This is because the aluminum is a little less stressed around the bolt when its warm. Spray some wd40 the night before.....run it hot and just loosen the bolt....never had a problem with that.
Old Feb 26, 2008 | 02:49 PM
denraweb's Avatar
Default Re: what is the best way to remove header bolts without breaking them (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">I only take em out when that car is warm. This is because the aluminum is a little less stressed around the bolt when its warm. Spray some wd40 the night before.....run it hot and just loosen the bolt....never had a problem with that.</TD></TR></TABLE>
I agree with this to a certain extent...problem with the bolts/nuts being warm when removing is that if the bolts are even a little over tightened, the bolt will easily snap completely off and basically when that happens, you're effed...even if only one bolt snaps, you still will have a major exhaust leak. So be careful...
Old Feb 26, 2008 | 04:34 PM
gsr dood's Avatar
Default Re: what is the best way to remove header bolts without breaking them (denraweb)
its not as bad as many ppl think.... if the bolt breaks just get a right angle drill and drill a hole in the bolt and get an extractor.... easier said than done.... but it still not gunna ruin ur life
Old Feb 26, 2008 | 04:45 PM
all-mtr-teg's Avatar
I use PB Blaster
Old Feb 26, 2008 | 05:56 PM
Jabinya's Avatar
Default Re: what is the best way to remove header bolts without breaking them (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">I use PB Blaster </TD></TR></TABLE>
X2
WD40 has nothing on PB Blaster
Old Feb 26, 2008 | 06:33 PM
63HMOOB's Avatar
the best way is to wait for the engine to cool down so you don't strip bolts. just use a socket and a long ratchet or a pole around it for leverage. some bolts you might need a wrench to get to. make sure you spray some kind of rust penetrate. GL
Old Feb 26, 2008 | 08:23 PM
blueDA9's Avatar
Default Re: what is the best way to remove header bolts without breaking them (63HMOOB)
I actually never had any problem with mine...
Old Feb 26, 2008 | 09:41 PM
kuja's Avatar
Default Re: what is the best way to remove header bolts without breaking them (blueDA9)
i broke my lower left stud before, it was great. extractors usually suck *****, but by some miracle and almost royally f'ing the hole, i got it out with one of the craftsman extractors. Anyway, with my ramhorn, i'm able to use an offset wrench on mine.
Old Feb 26, 2008 | 10:58 PM
Ciddogg's Avatar
just be gentle and you should have no problem and if it dose break weld a smaller bolt to it and then take it out that way. just another idea for you
Old Feb 27, 2008 | 12:54 AM
98GSRDC2's Avatar
Default Re: (Ciddogg)
i never had a problem with mine. just used wd40 the day before and let the car warm just to be safe
Old Feb 27, 2008 | 03:46 AM
mach0's Avatar
Default Re: what is the best way to remove header bolts without breaking them (Jabinya)
X3
Old Feb 27, 2008 | 10:43 AM
jr408's Avatar
ummmm...do it softly
Old Feb 27, 2008 | 01:00 PM
korndog's Avatar
well surprisingly i managed to find pb blaster on this island. so i will soak the bolts warm the car and give it a try
got_no_sol
10
Dec 28, 2007 12:29 PM
igo4bmx
Jul 8, 2007 12:10 PM
ekdriven
Mar 18, 2005 10:39 AM
Nice_Dc2r
Oct 23, 2003 10:41 AM
yellowbuffalo
Jan 1, 2003 06:06 PM
