B20vtec help! car runs like crap.
Old Feb 26, 2008 | 01:32 AM
J . K .'s Avatar
Default B20vtec help! car runs like crap.
hello honda-tech,
first of all i am new here but been around the honda scene since it boomed.
i think you guys are great. i have a dilemma
i just swapped in my B20vtec build into my 96 civic hatchback.
nothing too fancy the build is basically stock. it was running on my crx about 6 months ago flawlessly. heres the thing. my car runs like total **** and i dont know whats the problem anymore. i think it runs really rich cuz when i took out the spark plugs, i could smell fuel on it and it was wet. it has a hard time idling also. fuel pressure is good reading about 42psi. it also has a new distributor. the only check engine light it throws is iat and o2 sensors. the car was originally automatic so i had to extend some wires and did the 2 wire iacv and convereted my car to obd1 with a jumper. my ecu is also good cuz it is a chipped p28 with a basemap.tps and map sensors are good as it doesnt throw any codes and the tps is well calibrated still in its factory position. tried changing injectors but the problem still persisted. im running out of ideas and im thinking it might be electrical problem. can anyone chime on this?
opinions will be greatly appreciated so please feel free. if you have any more questions just ask me. thank you guys.
Old Feb 26, 2008 | 04:28 AM
djmatix's Avatar
try running the p28 at factory spec. (meaning take the jumper off that allows it to read from the external rom).
I've got a b20vtec setup in my car and it ran lean on every ecu I threw at it because of the added displacement. I'd say its probably the map your running.
Old Feb 26, 2008 | 05:14 AM
2redstars's Avatar
when you converted it to a 2 wire iacv, did you do the proper changes at the ecu? also, obd2-obd1 conversion harnesses are disigned to work with the EX 5spd models, so sometimes a couple changes need to be made to work on automatics or DX models.
make sure you did the iacv conversion properly.
Old Feb 26, 2008 | 05:31 AM
djmatix's Avatar
Default Re: (2redstars)
Yeah forgot about that. What a pain in the ***.
Also, this website will be your savior more than once!
http://technet.ff-squad.com/
Old Feb 26, 2008 | 06:39 AM
.Grimace's Avatar
footwork mastery
Default Re: (djmatix)
also since it's going to into an obd2 car, does your b20 have the sensor in the oil pump? i think it's the kcp sensor or something like that? if it doesn't you'll have to bypass that too.
Old Feb 26, 2008 | 05:39 PM
J . K .'s Avatar
Default Re: B20vtec help! car runs like crap. (J . K .)
thanks for all the replys. yes, i did the iacv fix properly according to the website and picture.
the kcp sensor on my oil pump? hmm dont get me wrong but since i already converted my car to obd1 i dont think i need that.
Old Feb 26, 2008 | 06:52 PM
.Grimace's Avatar
footwork mastery
ahh yes i forgot you converted to obd1
Old Feb 27, 2008 | 12:05 AM
J . K .'s Avatar
anyone else has opinions?
Old Feb 27, 2008 | 04:37 PM
jerryegk24's Avatar
fix your CEL and check timing..
Old Feb 27, 2008 | 05:19 PM
crxhf19's Avatar
Default Re: B20vtec help! car runs like crap. (jerryegk24)
the bad IAT sensor will make it run extra rich
Old Feb 27, 2008 | 07:59 PM
J . K .'s Avatar
Default Re: B20vtec help! car runs like crap. (crxhf19)
i just rechecked my timing and its fine. i also fixed all my cel but the problem still persists.
Old Feb 29, 2008 | 04:39 AM
J . K .'s Avatar
bump! the car also keeps bogging.
Old Mar 1, 2008 | 11:26 AM
idksparky's Avatar
good luck
Old Apr 3, 2008 | 10:21 PM
juncura1's Avatar
im not sure if you got this fixed, but if you are getting iat and o2 codes those are the first places to look. if your iat or o2 sensor are bad the ecu will automatically compensate not knowing what the proper mixture is by running a FULL RICH program as both are used to calculate air/fuel mixtures by the ecu.
Old Apr 3, 2008 | 11:22 PM
LastGenEK's Avatar
Default Re: B20vtec help! car runs like crap. (juncura1)
Are you useing a Catalytic converter???
Old Apr 3, 2008 | 11:23 PM
LastGenEK's Avatar
Are you useing a catalyic converter?
delinquent
Aug 3, 2009 01:13 AM
Yeah Daybid
May 23, 2009 07:06 PM
J . K .
21
Mar 3, 2008 04:34 AM
