help water leaking
Old Feb 25, 2008 | 10:26 PM
918eg's Avatar
Default help coolants leaking
so i did a head swap successfully and turns out somewhere on the block its leaking coolants. i've checked all the hose and its fine but when the car starts coolants leak from the block and drips down to the side of the oil pan.i've also checked the intake mani and its fine as well.i cant find the problem or did i miss something?
Old Feb 25, 2008 | 10:41 PM
philosofy1's Avatar
Default Re: help coolants leaking (918eg)
did you put everything on right? how about torquing down the head to specs?
is the head cracked?
Old Feb 26, 2008 | 07:47 AM
918eg's Avatar
Default Re: help coolants leaking (philosofy1)
i did the torquing right and i've checked the head when its off, it seems clean.unless its cracked and i miss it otherwise its okay...
ej8ster96
Sep 15, 2011 02:44 PM
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
Argetnia
Sep 18, 2005 08:34 PM
omgwtfhaxnub
Mar 20, 2005 03:29 PM
BANting
May 11, 2004 07:07 AM
