cams/crank at TDC, distro all the way back, timing still very advanced
put on the belt, triple checked for tdc. cranked the engine, alternator somewhat retarded, timing was way off. pull the distributor as far away as it can and the red mark is still like 2 inches on the right. what is that like 30btdc!
triple checked TDC again and all is lined up.
skipped a few teeth? i thought that was only if tdc was off. i turn the crank several times and recheck and its all lined up. i redid the belt and same thing. what could be wrong?
what's your car doin?? I think we might have the same prob.. https://honda-tech.com/zerothread?id=223233
[Modified by mrduque, 5:53 AM 7/6/2002]
figured it out!! check my last post.
https://honda-tech.com/zerothread?id=221612 [Modified by mrduque, 7:49 PM 7/6/2002]
[Modified by mrduque, 7:51 PM 7/6/2002]
hassan21
Oct 9, 2007 06:35 AM
