oil pressure question on my d16z6
Old Feb 25, 2008 | 07:55 PM
slammedz6ef's Avatar
Default oil pressure question on my d16z6
i just replaced my pcv valve, and when i bring it up to redline my oil pressure goes to 80psi, before i replaced it, it went to 60psi. it also leaks oil from my oil cap now when it didnt do it before......do i have too much oil pressure or what?
Old Feb 25, 2008 | 08:18 PM
Default Re: oil pressure question on my d16z6 (slammedz6ef)
anyone?
Old Feb 25, 2008 | 09:09 PM
anybody??????????????????????
Old Feb 25, 2008 | 09:28 PM
someone has to know?
Old Feb 25, 2008 | 11:02 PM
h/t is useless
Old Feb 26, 2008 | 12:00 AM
hott95ej2's Avatar
tit should normally be 60-70 psi at redline,but replacing your pcv would actually help the engine breathe better when it comes to crankcase vapor, it may be a stuck oil pressure relief valve in the pump itself but sounds like the you just need a new oil cap,its only 10 psi over stock spec, dont worry about it unless you having serious problems
Old Feb 26, 2008 | 09:58 AM
Default Re: oil pressure question on my d16z6 (hott95ej2)
so its not going to hurt anything? i just found out that the shop gave me a d15b7 pcv valve so im betting thats why its doing that
Old Feb 26, 2008 | 10:17 AM
jdmhondas's Avatar
I know on warm up my car see 80 lbs and near redline it get up that way too but as long as you have the valve in the right way and you have normal pressure at idle after its warmed up I wouldn't worry about it. And as far as the hule cap leaking its gotta just be the seal
Old Feb 26, 2008 | 10:20 AM
Default Re: oil pressure question on my d16z6 (jdmhondas)
the cap never leaked before till the pcv valve was change, when my car is warmed up it goes to 80psi at redline and when im at idel its at 25-29psi and when im cruising at 40mph in 5th gear its at 38-40psi
Old Feb 26, 2008 | 10:26 AM
jdmhondas's Avatar
not sure about the cap but the oil press seem a lil high to me but ever car is a lil different. The numbers don't seem to to be too bad tho. You might wanna get the correct valve and see what that does
Old Feb 26, 2008 | 10:32 AM
yea im probly going to get it done tomorrow and see what happens because i dont take my car out in the snow lol
high oil pressure wont hurt anything for right now , will it?
Old Feb 26, 2008 | 10:37 AM
smileycvc's Avatar
My oil pump is shimmed and it goes up over a 100 psi. I never have any problems with oil leaking from my oil cap or anywhere else for that matter. I think your problem is somewhere else.
Old Feb 26, 2008 | 10:48 AM
Default Re: oil pressure question on my d16z6 (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">My oil pump is shimmed and it goes up over a 100 psi. I never have any problems with oil leaking from my oil cap or anywhere else for that matter. I think your problem is somewhere else.</TD></TR></TABLE>
then do you think its was my oil cap gasket? i just put a almost new oil cap on today but i have not taken it out yet to see if it still leaks from the cap
Old Feb 26, 2008 | 10:59 AM
HONDACIVC93's Avatar
did you put the pcv valve in backwards? not letting any crank case pressure out would surely make your cap leak if its a little worn out.
Old Feb 26, 2008 | 11:02 AM
Default Re: (HONDACIVC93)
i put it in how the old one was in( is there a diagram that anyone knows of for me to see if i have it in right?)
bigsyke's Avatar
put the correct vtec PCV valve in asap
Old Feb 26, 2008 | 11:10 AM
Default Re: (bigsyke)
you think thats the problem
Old Feb 26, 2008 | 11:14 AM
HiProfile's Avatar
If a PCV valve is stuck closed and your valve cover breather is blocked up, you will build crankcase pressure higher loads. Adding pressure to the crankcase can in theory increase oil pressure, since oil pump inlet is at a higher pressure. The problem is that the oil bypass in the pump opens when the oil pressure is 50-60psi higher than the crankcase pressure.
Either you put the PCV valve in wrong, or your oil pump's bypass spring/oriface is not working properly.
FYI once warmed up, a normal L4 Honda motor should be ~10-15psi at 750rpm, and &gt;50psi at 3k rpm and above.
Old Feb 26, 2008 | 11:17 AM
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">If a PCV valve is stuck closed and your valve cover breather is blocked up, you will build crankcase pressure higher loads. Adding pressure to the crankcase can in theory increase oil pressure, since oil pump inlet is at a higher pressure. The problem is that the oil bypass in the pump opens when the oil pressure is 50-60psi higher than the crankcase pressure.
FYI once warmed up, a normal L4 Honda motor should be ~10-15psi at 750rpm, and &gt;50psi at 3k rpm and above.</TD></TR></TABLE>
well so you think there is anything messed up in my motor? and how do you put the pcv valve in wrong? i put it in the way it came out. at at around 3-4k its at 46-52psi
Modified by slammedz6ef at 12:29 PM 2/26/2008
Old Feb 26, 2008 | 11:27 AM
Default Re: (slammedz6ef)
my motor runs really strong, burns a little oil at high rpms(cant see it but can smell it) its just freaking me out because i dont want my motor to get messed up
Old Feb 26, 2008 | 12:17 PM
bigsyke's Avatar
the PCV will NOT affect oil pressure, it will affect gas crank case pressure.
If there is more pressure from the crank than vacuum from the IM (which is controlled by the PCV), then you will leak past your oil cap and intake arm breather tube which is the 2nd half of your PCV system.
I would just go and get the $3 part, and know your safe.
Old Feb 26, 2008 | 12:57 PM
alright, thanks man
Old Feb 26, 2008 | 01:34 PM
alright, so i just got back in from looking at my car and i found something that looked like it some sort of gasket sealant or something plugging up the the part on my intake where the oil breather hose goes into, so could that be the problem?
Old Feb 26, 2008 | 05:47 PM
im pretty sure its fixed now, it doesnt idle surge anymore, oil pressure at redline is about 65-68psi, it doesnt leak oil anymore and runs a hell a lot better after i unplugged the intake and got the right pcv valve in. thanks everybody who helped/tried to help
slammedz6ef
Feb 27, 2008 09:18 AM
Gsir8
Jul 1, 2007 02:12 PM
aznd87
Nov 6, 2006 01:32 PM
98lude
Aug 17, 2002 10:42 AM
