conversion questions
Old Feb 25, 2008 | 07:29 PM
Slosc2's Avatar
Default conversion questions
I just picked up a 90 dx hatch. It has a si cable trans and a complete 94 z6 engine (valve cover to oil pan.) I have a p28 ecu, and a jumper harness.
How can I tell if I have a dpfi obd0 to obd1 jumper harness or better yet the correct jumper harness?
Anyone happen to have ecu pinouts for both ecu's handy?
Anyone happen to have saved a writeup that was done for this particular mess? I have been searching for hours and can only find mpfi obd0 to obd1 writeups.
Old Feb 26, 2008 | 12:09 AM
143MYVTECEF's Avatar
Default Re: conversion questions (Slosc2)
to tell if its been converted look at the factory harness under the ecu cover. it should have 4 extra wires spliced into it. 2 additional injectors and 2 wires for the dizzy. thats for dp to mp .now for obd0 - obd1 look at where the ecu and harness meet. the jumper is gonna look outta place between those two items. also look for the 4 wire o2 and grey square dizzy plugs.. all obd1 items
Old Feb 26, 2008 | 07:28 PM
Slosc2's Avatar
Default Re: conversion questions (143MYVTECEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 143MYVTECEF &raquo;</TD></TR><TR><TD CLASS="quote">to tell if its been converted look at the factory harness under the ecu cover. it should have 4 extra wires spliced into it. 2 additional injectors and 2 wires for the dizzy. thats for dp to mp .now for obd0 - obd1 look at where the ecu and harness meet. the jumper is gonna look outta place between those two items. also look for the 4 wire o2 and grey square dizzy plugs.. all obd1 items</TD></TR></TABLE>
I find it has a xenocron jumper harness, checked his site and it says it must be converted to mpfi first. I dont have the cars stock ecu, but it certainly does not look like anything has been altered. I have a better chance to look at everything tomorrow so I will post up my findings.
V-tec_91_Hatch
Dec 3, 2012 12:18 PM
zapzach
19
Feb 24, 2012 10:35 AM
bobbyisking
Jul 7, 2008 09:22 AM
88da3
Nov 13, 2003 01:12 PM
wickedEFguy
Feb 11, 2003 03:01 PM
