msd rpm activated switch used as a 2step??
the reason i ask is my friend has the activated switch i can have for free.. so im just wondering if it wud work
the easiest way is with the 2 step module, it is as easy as hooking it up to your ebrake. you have to do it the reverse though, put 12 volts to the 2 step and ground it through the ebrake.
up until i popped for the s300 thats the way i used it. worked well.
well the rpm activated switch just activates something or turns it off.
so it will work to activate a rev limmiter, but you still need the rev limmiter. so you would still need to get a 2 step.
if you use it to activate the 2 step, you still need a way to turn it off. or disengage it. to me it is just overly complicated to do the same function as the 2 step module.
it is all self contained.
