How to replace alternator belt ?
Old Feb 25, 2008 | 05:49 PM
vietelement's Avatar
Default How to replace alternator belt ?
i got a 99 civic ex, d16y8 motor, and i need help on how to replace an alternator belt.
is there a site or can someone tell me the main things that i gotta do ?
and don't tell me to search google cuz i already have.
Old Feb 25, 2008 | 06:01 PM
2redstars's Avatar
looking at the top of the alternator, there is a nut, i believe 12mm, loosen that, then underneath the alternator there is another one, 14mm i think, loosen that one, go through the wheel well. then you should be able to slide the alt forward, remove belt, put new one on. then take a small crow bar/tire iron/big screw driver/pipe or what ever you can find, and use it to push on the alternator until the belt is tight, then as your holding it tight, tighten the top 12mm bolt, once thats tight, you can let go. then tighten the bottom 14mm bolt.
el1cuban
Apr 18, 2009 10:10 AM
nemesiskrp
Apr 14, 2009 10:10 PM
integracing86
Oct 26, 2006 01:52 PM
bbrian
Feb 13, 2006 12:52 PM
crxforum
Jul 28, 2004 11:47 AM
