help with trans flush
i tryed doing a drain and fill on my 00 si but i never thought the trans had more than 2 plugs so im not sure which 1 is to drain and fill. pictures will be very help-full.
Cool Cool Island Breezes. BOY-EE
The drain bolt is the only bolt that has a 3/8'' square hole in it's head.
Basically, you just put your 3/8'' ratchet right up to the bolt. No socket needed. It's at the lower end of the trans.
The Fill bolt is 17mm and right above the passenger axle. I dont have pics. TAKE OFF THE FILL BOLT FIRST!!!!!!!!!!!!!!!!!!!!!
Use new crush gaskets for both bolts.
doom26464
Jun 18, 2008 07:10 PM
RCautoworks
Feb 16, 2003 11:16 PM
