Car starts then dies, no prove out circuit
Old Feb 25, 2008 | 01:07 PM
c0d0r's Avatar
Default Car starts then dies, no prove out circuit
Ok, the car's an 89 si w/ about 272k miles on the body-b16a1 swap.
I have a new dizzy on it w/ about 3k miles on it and just put a new main relay on it today. My problem is that I was driving home from tech school today and the car just died. Well...I was Having main relay issues but that didnt fix it, had the car towed home where it is now.
When I turn the key to start, the prove out circuit doesnt work(none of the dash lights come on). The car turns over and starts but then immediately dies, i'm thinking something to do w/ the ignition switch maybe? HELP! I have school to go to!
Old Feb 25, 2008 | 01:16 PM
alscrx's Avatar
Default Re: Car starts then dies, no prove out circuit (c0d0r)
If no lights come on, Check all your fuses!
Also, did you replace the main relay with a new one or used one?
While holding the relay, Does it click on and off??
Modified by alscrx at 5:31 PM 2/25/2008
Old Feb 25, 2008 | 01:18 PM
c0d0r's Avatar
start it w/ a screwdriver? Which wires do I have to bridge?
Also..update, when I turn the key all the way to start w/o the clutch in the lights come on and the pump primes. Keep the ideas coming! Thanks!
Yeah, the relay was replaced w/ a brand new oem from honda
60 bucks though...
Old Feb 25, 2008 | 01:20 PM
alscrx's Avatar
Default Re: (c0d0r)
So then check your clutch switch behind the clutch pedal...
Jump the 2 wires in that clip and start your car.
Old Feb 25, 2008 | 01:22 PM
c0d0r's Avatar
if it was a clutch switch wouldnt the car not turn over w/ the clutch depressed? Mine does that..it just starts and then dies...I need to find something quick..my battery is getting sluggish..bullshit.
Old Feb 25, 2008 | 01:26 PM
alscrx's Avatar
Default Re: (c0d0r)
Mine did the same thing, start and die quick. My main relay was only clicking once. Are you sure its not your main relay?
Also remove your column cover and check your ignition switch...
Old Feb 25, 2008 | 01:29 PM
c0d0r's Avatar
alright, i'm thinking it's the ignition switch. Let's look at it this way, it has the 3 settings on the switch.
Numerals I, II, and the third one.
I can put it to on, being II and toggle it a bit and the lights will come on and the car starts and runs.
If I cut it off and do it without jiggling the key it will start and just shut off. Can the ignition switch on these cars cut power to the main relay at any time?
Old Feb 25, 2008 | 01:34 PM
grog's Avatar
Default Re: (c0d0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0d0r &raquo;</TD></TR><TR><TD CLASS="quote"> Can the ignition switch on these cars cut power to the main relay at any time?</TD></TR></TABLE>
yes, its acting like you are removing the key.
Old Feb 25, 2008 | 01:42 PM
c0d0r's Avatar
Default Re: (grog)
alright then, which wires do I bridge on the backside of the switch?
Old Feb 26, 2008 | 11:22 AM
alscrx's Avatar
Default Re: (c0d0r)
does your check engine light come on?
Old Feb 26, 2008 | 11:57 AM
c0d0r's Avatar
Thanks guys! Fixed the problem, ignition switch on the electrical side, replaced the switch and harness. Good deal!
JusAccord
Mar 29, 2012 06:38 PM
SiRkid
Aug 5, 2009 04:42 PM
tgorman928
Acura TL, RL & ZDX
Feb 23, 2006 10:07 PM
Fuzion
20
Sep 2, 2004 07:17 PM
quincy2729
May 17, 2004 09:34 AM
