crx engine removal question
trying to take the motor out of my 88 hf, and being held up by the rear trans mount, the one that has the 3 bolts holding it on, i cant break em loose, and i cant even get to the one going through the center, has anyone else ran into this, any pointers?
The rear mount has 1 bolt going through it....remove that and leave the bracket on the motor.
Soak the bolt with PB blaster or wd40
Use a 1/2"inch drive breaker bar and you can reach it from under the hood!
First soak the bolts in PB Blaster. Let it sit for a couple mins.
Then, go at it with your socket wrench. I used a 1/2 drive, 12" extension, 6" extension, and a six point bolt (I think 14mm). You could also use a breaker bar and have more torque if its a real PITA.
[ivi]
12
Apr 26, 2012 10:56 AM
BoombasticSloth
May 2, 2010 02:15 AM
swiftstyles
Dec 23, 2004 05:35 AM
