HELP!!! B17 N/A Build
Old Feb 25, 2008 | 11:04 AM
phantomh22's Avatar
Default HELP!!! B17 N/A Build
Alright, so I have a b17a motor with all stock internals I want to build for N/A (*ON 91 octane PUMP GAS*). I'm looking to make this a decent street car. I have a set of 00-p73 (JDM ITR) pistons pressed on Ls rods, and I was wondering if the ITR pistons would fit in my block safely, using the Ls (pr4) rods and b17 crank. If not, what rods or crank would I have to get? I'm also planning on ordering a pair of itr cams and valvesprings / retainers. What compression ratio should I expect to get? I'm going OEM on this build as much as I can, so if you have a nice setup in mind for the b17 let me know. All input is appreciated!
Old Feb 25, 2008 | 04:08 PM
Da9teggy92's Avatar
you need to use the b17 rods. and to use the itr pistons you would need to machine the rods to fit
PACT man
Jan 19, 2009 12:59 PM
Civic138
12
Feb 9, 2007 03:03 PM
mikkey1
Oct 4, 2006 11:04 AM
Barn Man
Jul 20, 2003 07:36 AM
JDMdaN.A
Apr 5, 2003 04:26 AM
