Quick lil wire question
Old Feb 25, 2008 | 09:30 AM
jax97hx's Avatar
Default Quick lil wire question
ok...so i was pulling out my harness, i went to disconnect the two big plugs on the drivers side and a lil green wire got snagged and pulled out. im just curious what this wire is for.
Finnaly a reason for me to post ..been a member for a little while and mostly just read
ok imma go take a pic and post it
Old Feb 25, 2008 | 09:42 AM
jax97hx's Avatar
Default Re: Quick lil wire question (jax97hx)
In case you cant tell in the pic its the green one next to the plugged blank spot in the plug
Any help with what the function of this wire is would be great thx
Old Feb 25, 2008 | 10:06 AM
jax97hx's Avatar
ttt
Old Feb 25, 2008 | 10:24 AM
ekb16's Avatar
get urself a wireing diagram and trace it to see what it is
Old Feb 25, 2008 | 10:52 AM
jax97hx's Avatar
Default Re: (ekb16)
i have ..they done show u plug pinouts
Old Feb 25, 2008 | 10:56 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (jax97hx)
What harness is this for? Car? Motor?
Old Feb 25, 2008 | 10:57 AM
instrument's Avatar
you need to push that pin back out, and make sure the wire is in that clamp fairly well.
and there's no way i'm digging through the manual to tell you what the wire is for..good luck on that one.
Old Feb 25, 2008 | 11:22 AM
Blk00EJ8's Avatar
It's somewhat irrelevant what it's for since fixing it isn't too hard. Pop the pin out from the other side of the clip, repinch the pin onto the wire, and then reinsert the wire into the clip.
Old Feb 25, 2008 | 01:33 PM
jax97hx's Avatar
Default Re: Quick lil wire question (Blk00EJ8)
97 civic hx -- d15b swap but thats irrelivent its the stock obd2 harness .. currently getting modified ...
i know how to fix it i was just curious what the wire is for so if i was having problems down the road id know wheather that wire might be the problem
basically just wanted to know for peace of mind .. its already fixed
Old Feb 25, 2008 | 06:52 PM
jax97hx's Avatar
well i found out that the wire goes to a sensor plug i no longer use due to obd1 motor thx neway
JacksonD
Jan 7, 2011 11:51 PM
daklown
Jun 9, 2004 10:12 PM
