Headgasket Installation
Old Jul 5, 2002 | 04:49 PM
Chuji's Avatar
Default Headgasket Installation
Im putting together an ls/vtec motor and im about to slap the head on. I am using an OEM 3-ply gasket. There are 4 small brass rings that are on the headgasket, will these prevent the gasket from sealing? Do I need to remove them and if so how, looks like they are in there pretty good.
Old Jul 5, 2002 | 04:54 PM
slooowDX's Avatar
Default Re: Headgasket Installation (Chuji)
those rings keep the 3 layers of the gasket together, if you want to "modify" the stock gasket to a 2 or 1 layer then the rings must be removed, but leave them on if you are using it like intended
Old Jul 5, 2002 | 05:32 PM
Chuji's Avatar
Default Re: Headgasket Installation (slooowDX)
One more question, i have a 00si head with very low miles on it. Do I still need to remove the oil control orifice and replace the o-ring or should it be fine?
Old Jul 5, 2002 | 10:10 PM
GreenD's Avatar
as long as u havent removed the orifices u should b fine.
eh2-hb
Oct 13, 2005 10:01 PM
Vincent.
Nov 2, 2004 01:46 AM
vspec12
Mar 27, 2004 09:10 PM
Vero
10
Jan 28, 2004 02:20 PM
WEPN R
Oct 8, 2002 06:50 PM
