How do you know when your clutch is failing?
Old Feb 25, 2008 | 08:02 AM
91tegra07's Avatar
* B A N N E D *
Default How do you know when your clutch is failing?
I have a 91 integ with a 10 year old stock clutch. Occasionally, It'll grind on 2nd gear even when I press the clutch pedal all the way down. Is that from a failing clutch? What are the signs when your clutch gives? Thanks.
Old Feb 25, 2008 | 09:52 AM
korndog's Avatar
Default Re: How do you know when your clutch is failing? (91tegra07)
does the grind happen at a high rpm shift or just regular driving?
Old Feb 25, 2008 | 09:56 AM
Force1stiptopped's Avatar
Default Re: How do you know when your clutch is failing? (korndog)
grinding is normally a sign of bad syncos, usually not the clutch
Old Feb 25, 2008 | 10:03 AM
91tegra07's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korndog &raquo;</TD></TR><TR><TD CLASS="quote">does the grind happen at a high rpm shift or just regular driving?</TD></TR></TABLE>
Just on regular driving. Like from a stop sign I'll exellerate normal.
Old Feb 25, 2008 | 10:04 AM
91tegra07's Avatar
* B A N N E D *
Default Re: How do you know when your clutch is failing? (Force1stiptopped)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Force1stiptopped &raquo;</TD></TR><TR><TD CLASS="quote">grinding is normally a sign of bad syncos, usually not the clutch</TD></TR></TABLE>
I know nothing about clutches. So does that mean the tranny fluid is bad? I changed out the fluid last year with penziol stuff.
Old Feb 25, 2008 | 10:12 AM
jdmjunkie8's Avatar
Most likely the grinding is synchros but if its the clutch going then it will start to slip.
Old Feb 25, 2008 | 10:24 AM
VTEC_PRODUCTION's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegra07 &raquo;</TD></TR><TR><TD CLASS="quote">
I know nothing about clutches. So does that mean the tranny fluid is bad? I changed out the fluid last year with penziol stuff. </TD></TR></TABLE>
if your grinding then your tranny synchros are going bad. so its either replace or repair from this point.
Old Feb 25, 2008 | 11:57 AM
tucker8235's Avatar
You'll know your clutch is going bad when it starts to slip. It will usually be gradual and you'll definitely notice that the rpms are going up faster than the car is accelerating. It is kind of like when it is wet out and you floor it - rpms go up but the car doesn't really go anywhere. Sometimes they just break and you can't engage a gear at all.
Old Feb 25, 2008 | 01:19 PM
91tegra07's Avatar
* B A N N E D *
Default Re: (tucker8235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tucker8235 &raquo;</TD></TR><TR><TD CLASS="quote">You'll know your clutch is going bad when it starts to slip.</TD></TR></TABLE>
When you say "when it starts to slip", does that mean that grinding sound?
Old Feb 25, 2008 | 01:23 PM
BoSox46GSr's Avatar
Default Re: (91tegra07)
When your clutch "slips" it's basically like your trying to accelerate, but the car can't keep up with the engine because the clutch is worn. You will notice the RPM's going up but if you look at the speedo, it stays somewhat stationary. It sounds like it's your synchros though, good luck.
Old Feb 25, 2008 | 02:37 PM
91tegra07's Avatar
* B A N N E D *
Default Re: (BoSox46GSr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote"> It sounds like it's your synchros though, good luck.</TD></TR></TABLE>
What are Synchros? And how do I replace it? Sorry for the ignorance.
Old Feb 25, 2008 | 02:52 PM
Mcdc2's Avatar
When you say "when it starts to slip", does that mean that grinding sound? </TD></TR></TABLE>
LOl no it means this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote">When your clutch "slips" it's basically like your trying to accelerate, but the car can't keep up with the engine because the clutch is worn. You will notice the RPM's going up but if you look at the speedo, it stays somewhat stationary. It sounds like it's your synchros though, good luck.</TD></TR></TABLE>
Old Feb 25, 2008 | 03:00 PM
posHonda's Avatar
I think youre better off getting a new tranny than trying to rebuild your current one especially since its just a cable LS. Just get one in good condition.
STEVE-O7
Oct 10, 2007 05:18 PM
teggy2154
Nov 15, 2005 10:33 PM
dynamyks
Aug 21, 2005 02:46 AM
AspectIndustries
Jan 5, 2004 07:49 AM
faultofhumanity
30
Sep 13, 2003 10:47 PM
