rebuilding a type r
Old Feb 25, 2008 | 07:58 AM
honda_ek9's Avatar
Default rebuilding a type r
Is it worth rebuilding a type r motor to stock...i mean the motor is blown..has a bent valve, and whole in piston thats all i know for know...so i was wondering if is actually worth rebuilding it or picking up another ITR or gsr or b20V....and how much would it cost me to do all this...i just want to build it back to stock...so it will run and is use for daily driving/autocross...motor is goin into a civic hatch...so what do you guys think???..thanks..my buget it about 2-2500..
Old Feb 25, 2008 | 08:09 AM
jomama's Avatar
if this were the OEM engine for an R, people may lean towards rebuilding it. with the engine going into a civic hatch, people may lean towards swapping engines and starting over. personally, with that 2-2.5k budget, you could go either way... sell the engine to someone who will rebuild it to their specs and with your existing budget, you could easily buy another engine... ITR/GSR/b20/whatever.
... you may want to be a liiiittle bit more specific with what's going on with the head/block so we could assess what parts need to be changed. i'm rebuilding my daily gsr with upgraded cams/pistons/valvetrain (and buying tuning equipment) and it's going to be about 1500 in parts. when i sell the old parts, i'll probably be looking at having spent about 1000. depending on what's wrong with your engine, you maaaay be able to get it done cheaper. GL.
Old Feb 25, 2008 | 07:03 PM
honda_ek9's Avatar
Default Re: (jomama)
ummm...sounds good..how much do you think i can sell this motor for...and how much would it be to redo or rebuild my head and block..J/W...thanks...
Old Feb 25, 2008 | 09:04 PM
HONDAPARTSMANMIKE's Avatar
Default Re: rebuilding a type r (honda_ek9)
WHY NOT JUST REOLACE THE BENT VALVES AND REPLACE THE DAmaged piston. how do u know it has a whole in it
Old Feb 26, 2008 | 05:31 AM
jomama's Avatar
pictures of what's going on would be nice to help assess the situation and figure out how much the engine's worth (head/valves/block/pistons/cylinders/sleeves/any holes in the block/etc) ^ no sense in making the same mistake as the OP and spelling "hole" wrong
Old Feb 26, 2008 | 05:49 AM
honda_ek9's Avatar
Default Re: rebuilding a type r (HONDAPARTSMANMIKE)
i know...thats why i gotta take apart the motor...but right know dont really have time because of school and work...but ill be free tomorrow...so first i have to unplug everything and then drop the motor...and last time i tried taking off the head but then i couldnt get the cams off...so i was like F*** it...didnt want to mess it up...so do you guys have another way of taking it out...i mean when i tried to take unscrew the bolt by the cams it would spin...which i wouldnt be able to unscrew it...
Modified by honda_ek9 at 8:43 AM 2/26/2008
Old Feb 26, 2008 | 05:51 AM
honda_ek9's Avatar
yea ill try too...once i get the motor apart...do you guys know how much it would be to fix a bent valve and messed up head...and for fixng a block...thanks...
Old Feb 26, 2008 | 05:53 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">i know...thats why i gotta take apart the motor...but right know dont really have time because of school and work...but ill be free tomorrow...so first i have to unplug everything and then drop the motor...and last time i tried taking off the head but then i couldnt get the cams off...so i was like expletive it...didnt want to mess it up...so do you guys have another way of taking it out...i mean when i tried to take unscrew the bolt by the cams the cams would spin...which i wouldnt be able to unscrew it...</TD></TR></TABLE>
Might be better then if you just didn't touch it and try to sell as is. GL with it.
Old Feb 26, 2008 | 07:56 AM
honda_ek9's Avatar
Default Re: rebuilding a type r (Dave_B)
i mean i want to be able to learn how to build a motor too...so in the future i would know what to do...but if its best for me to get a new motor then i will...how much will i be able to sell this motor for...motor is still clean...
Old Feb 26, 2008 | 11:45 AM
RC_C0LA's Avatar
* B A N N E D *
perhaps buy some literature on B series building rebuilding.
and then after that decide if its for you.
its good to learn anyways, and it will help you decide if you want to keep the R or buy something already built. or build it yourself.
Old Feb 26, 2008 | 12:16 PM
len's Avatar
len
Default Re: (RC_C0LA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC_C0LA &raquo;</TD></TR><TR><TD CLASS="quote">perhaps buy some literature on B series building rebuilding.
its good to learn anyways, and it will help you decide if you want to keep the R or buy something already built. or build it yourself.</TD></TR></TABLE>
While you're at it, I know it's just a message forum, but try to write in complete sentences so others can help you. Try to ask questions that give you an answers, not questions that give you opinions.
I see what you're trying to do but it's like asking people whether or not I should wipe my *** with Charmin Ultra Strong or Charmin Ultra Soft toilet paper. There are ways you should wipe your *** and there are ways you shouldn't. How about telling us how you're wiping your *** first and we'll tell you if you're doing it right or wrong.
PS. Was it necessary to make two entirely different threads about the same question?
Old Feb 26, 2008 | 01:57 PM
RC_C0LA's Avatar
* B A N N E D *
BTW: make sure you wipe back to front.
Old Feb 26, 2008 | 05:41 PM
honda_ek9's Avatar
Default Re: (len)
hahaha...i like that theory...but yea im sorry...will try to ask better questions and write it in complete sentence next time....
dj theoretic
Oct 30, 2008 10:18 AM
GSRdad
May 27, 2006 03:52 PM
B18C5-EH2
Mar 21, 2005 03:56 PM
92integraVTECgsr
Dec 15, 2004 07:29 AM
FlipboiGSR
Mar 23, 2002 11:15 PM
