Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Door panel removal?
Old Feb 25, 2008 | 06:03 AM
Klutch's Avatar
Default Door panel removal?
Did a search and looked at the FAQ's. I couldn't find anything on door panel removal for the 06-08. Getting ready to tint my windows and I've become fond of removing the door panels instead of jambing the weatherstripping under. I usually try to find good visual reference for the door panel removal just so I don't bust anything. Anyone know if a good DIY exists someplace?
Old Feb 27, 2008 | 07:05 AM
HA0LEFIED's Avatar
Default Re: Door panel removal? (Klutch)
im guessing its like any other civic.. you unscrew the window switches and there are screws by the speakers.. and the door panel is held by clips so carefully pry it off.
Old Feb 27, 2008 | 07:09 AM
Klutch's Avatar
Default Re: Door panel removal? (HA0LEFIED)
Well that pretty much generalizes any vehicle but I appreciate the reply. I did go ahead and get them removed without breaking anything. Some of them quite often have little tricks or things you can't readily see.
Old Feb 27, 2008 | 07:11 AM
Mik3's Avatar
Where the door handle is, theres a pop out clip and theres a screw behind there.
Remove the little panel in the corner of the front of the window.
Behind the silver trim that you use to open and close the door are two screws.
The rest are just clips that will come out when you pull the door panel.
Pull out and up to remove door panel.
Old Feb 27, 2008 | 09:08 AM
bigluelok's Avatar
this is for a 4 door
I just removed all my door panels (07 Si Sedan) for tinting. I don't have a guide, but I can quickly tell you what I did. If I remember correctly, all doors are very similar.
1) Remove the cover inside the door lever. You will see two fasteners, a screw and a clip. Remove the screw, and remove the fastener by pushing the center pin in (~2mm).
2) Remove the plastic panel that holds the window control switches by carefully prying near the handle side of the triangle. Remove the silver #2 screw. Unplug the wiring connector.
3) Stick your fingers under the bottom of the door panel and pull very hard and evenly. Use 2 hands to distribute the pulling force over a wide area. There are 7 snaps that hold the panel on.
4) Lift the door panel up and pull out. Be careful not to scratch the metal near the window guides.
5) Remove the door handle assembly by snapping the entire triangle out, then pulling it back through the hole. There is no need to dislodge the cables.
Disclaimer: I am not responsible for any damage caused by these instructions. Proceed at your own risk.
Old Feb 27, 2008 | 11:08 PM
mInI m3 Hondeezy's Avatar
Here another with pics i used to change my speakers. http://www.8thcivic.com/DIY/sp....html
jruiz094
Apr 4, 2010 04:59 PM
awdgsx96
Aug 29, 2007 05:40 PM
todd.ludwig
May 1, 2006 02:27 AM
1997exciv12w3
Sep 3, 2002 05:12 PM
PainfulTeg
Aug 3, 2002 05:30 PM
