b16 in dc2
ok so i have a 97 integra LS its of course obd2a, well i just bought a b16a2 from a very cool person on this board(had to drive 300 miles but for 600 bucks i cant complain) my question is what harness would be best to use? he gave me the obd2b harness but im not sure if it just plugs up or not....what will i have to swap out if anything??? i have an obd1 gsr ecu and the conversion harness but what else will i need??? thanks guys the only reason i ask is because when i had a b16a2 in my eg hatch i used the obd2a gsr harness and it plugged in perfectly like the faq said.
it is a direct drop in and bolt on. except on the driver side motor mount bracket on the b16 engine . u can swap that bracket with your LS and then u can reuse all your LS motor mounts, rear t bracket.shift linkage , axles.and everything .even the LS throttle cable. and p72 ecu wont work because air and fuel ratio is different.u can get a chipped p28 ecu or p30 or p05.
or get that p72 ecu chipped
and u can reuse exhaust manifold and down pipe from your LS and it will bolt right on to b16a engine and your cat convertor
