Electrical Short
ok, pretty much i have a ground short on the radio circuit.. meaning no clock/turn signals/radio and what not.. the fuse thats under the hood and not the dash.. been like this for a year now.. a week ago my running lights went, same issue..
putting a meter on the fuse point.. i am reading 12 volts. so yes a ground short... where and what do i go about fixing this? what wire do i look for. or any ideas maby a bad component?
also off topic from above.. how do i tell if i have stock gsr/b16 cams or itr cams?
I think the wire that causes this is a blue one. it might be touching metal behind the deck. make sure all wires not connected are caped and you should be good. use thee right size fuse or you could melt wires.
drjondurst
Nov 30, 2004 03:35 PM
