Im sorry but I have a very noob question.
My friend is doing a gsr swap into his EK and he dosent know what rear mount he needs. He also is not sure what harness to use. His car is a 1996 Civic hatchback DX and im not sure what year his engine is. He purchased the entire clip. Sorry for the question, i know if i try hard enought at searching i could find the answer but im kinda lazy and want as answer quick. thanks in advance
yeah makes sense to reuse the original harness, he keeps insisting that it dosent work
About the mount it makes perfect sense, ok guys thanks, you know although im a DA guy ive always wanted an EG, ive never owned a civic, i would like to though,thanks guys for your patience
USE OBD2 DISTRIBUTER ALTERNATOR AND COMPUTER USE SAME HARNES JUST RUN THE VTEC OR USE A 99-00 SI HARNESS CAUSE IT GOES THROUGH THE FIRE WALL
i think its a little more complicated than that dx use a 3 wire iac also the ckf sensor is 3 wires both need to be made 2 wire like b series have and also a fix at the ecu connections and if im right your car is a 96 which runs obd2a not obd2b like the 99 si has just hit me up if you need more info
Dasanib20T
Apr 9, 2010 11:24 AM
JDMister_EF9
Northwest (Sales)
Mar 4, 2007 09:12 AM
