are the axles wit abs the same as the ones with out abs?
Old Feb 24, 2008 | 06:47 PM
honda craz's Avatar
Default are the axles wit abs the same as the ones with out abs?
man this sucks my 93 integra rs had an axle problem so i changed both axles well my car has no abs but i got the abs axles they look the same as the ones witout abs other then the ring on the end >well my ?is are the ones wit abs shorter then the ones without ?cuz one day i am going about 70 on HWY and all of sudden my car started to rev all high i thought my clutch went out bt when i pulled over my clutch was fine my right axle was shaking or vibrating and it didint pop out it was wierd at the time then i pushed it in alittle and limped it home.Next day i pulled the axle out and the teeth past the locking ring was worn done to a smooth surface.sorry for a long ? i replaced it it it works ok but everytime i slow down to almost a stop u hear a clunk on the axle>wtff man i am tired of this stuff happening plz anybody help me . abs or non-abs which ones?
Old Feb 24, 2008 | 07:48 PM
1dumbscreenname's Avatar
Default Re: are the axles wit abs the same as the ones with out abs? (honda craz)
based on what your title says. yes.
Old Feb 24, 2008 | 07:55 PM
all-mtr-teg's Avatar
Lengths are the same, as you said, only difference is the abs ring. If you installed it wrong, it doesn't matter if you got an axle w/ or w/o abs. The first time you didn't pop the axle in far enough into the tranny and the axle popped out. That's why your rpms reved and the car didn't move, and that's what caused the teeth on the end of the shaft to get eaten up. You better change your tranny fluid, I can guarantee you will have those metal shavings in your tranny fluid. May also want to get a magnetic drain plug to remove the rest of the metal shavings.
Old Feb 24, 2008 | 08:10 PM
honda craz's Avatar
Default Re: are the axles wit abs the same as the ones with out abs? (all-mtr-teg)
wht about the clunk on slowing down?also cuz i have to move my car like in neautral like move it forward in my drive way so my girlfiriends car fits cuz she works nights and i work days.when i move it by pushing it when i start pushing it about a couple inchs then theres like a big clunk like something hoped orjumped out of place but its drive able and only sumtimes when i turn it does tht clunk nosie like it wants to pop out i dont under stand the axle is in as much as it can about 1 fourth of an inch from the tranny i even gressed up the wheel bearings with bearing gresse i dont understnad any tips on how to put the axles in or how to make they are in?
Old Feb 24, 2008 | 08:25 PM
When I install an axle I always hit the wheel end w/ a 3 lbs sledge hammer just to make sure its in all the way. You know the ring has seated when it is almost impossible to remove the axle by hand. Most times you will need a big screw driver or pry bar to remove the axle. It shouldn't be out of the tranny 1/4". The shaft should be pretty flush w/ the tranny. The could be why your getting the clunk noise it may be popping out again. Also, no need to grease you wheel bearing, those are sealed.
Old Feb 24, 2008 | 08:37 PM
honda craz's Avatar
well when the first time the axle broke iwas turning left and then i lost all brake pressure and all of sudden i couldnt move and when i got out to check and my friend pressed the brake and the whole wheel moved in and out well wht happen the axle nut unscrewd and fell off and then with the movemnet of the car and the play of the screw the screw broke off got lucky my whel and rotor fell off well it didnt thank god but when i got it home i jacked it up and remove the wheel and the rotor fell anyways and exposed i thought they were the bearings cuz both pieces were the axle end goes in at fell out and i just grease them up before i put those piesces back together and put an axle on ...but u said u hit it at the end to make sure it was in right well was the lower ball joint still off or wht?
Old Feb 24, 2008 | 08:43 PM
PM me
Old Feb 24, 2008 | 09:04 PM
honda craz's Avatar
sorry man i cant pm u right now i am on trial lol but yea and any tips to get new sway bars and bushing and stuff like tht i have a fully built b16a on ys1 tranny its funny cuz all tht stuff wit messed up axles i really thouth i put them in sercurly i double checked
Old Feb 24, 2008 | 09:06 PM
WEKSOSDA9's Avatar
make sure ur rear mount is good too cause if it is broke or off a lil bit it can cause axle pop out.
Old Feb 24, 2008 | 09:55 PM
You may also have just gotten a bad axle. I used to work at autozone and had lifetime waranty on my axles. Sometimes rebuilt axles are hit and miss, you may get a good one that'll last years, and you may get one that is already bad before you even install it.
felixjr18
Dec 21, 2008 07:22 PM
204hatch
Apr 4, 2008 09:11 AM
nihad
Jul 21, 2007 09:38 PM
BB4
Mar 9, 2006 07:46 PM
philosofy1
Oct 26, 2005 02:08 PM
