head gasket
Old Feb 24, 2008 | 04:58 PM
fudo1252's Avatar
Default head gasket
i was changing the head gasket and when i pulled the head off the cylenders had like u shaped marks on them in this normal the engine has 80000 miles on it and when u change the head gasket should you change the whole headgasket set or just the headgasket
Old Feb 24, 2008 | 05:29 PM
95ProjectEJ1's Avatar
Default Re: head gasket (fudo1252)
If you are replacing the headgasket you might as well change the valve cover gaskets since you have to remove the VC etc. I think the OEM gasket set for the VC is like $17
Old Feb 24, 2008 | 05:32 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fudo1252 &raquo;</TD></TR><TR><TD CLASS="quote">i was changing the head gasket and when i pulled the head off the cylenders had like u shaped marks on them in this normal</TD></TR></TABLE>
Can you take pics?
Old Feb 24, 2008 | 06:04 PM
fudo1252's Avatar
Default Re: head gasket (ddd4114)
sorry cant take pics no camera right now they are u shaped ingraved in the top of the cylernders like the valves are hitting them but the engine runs great sounds good too so idk i never opened up an engine before so im not sure if that is bad sorry 4 the spelling
Old Feb 24, 2008 | 06:08 PM
ddd4114's Avatar
You mean like the 2 U-shaped things in this piston?
Old Feb 24, 2008 | 06:17 PM
fudo1252's Avatar
yeah just like that i didn't know what that was never saw a piston before so its all good i guess thanks a lot i was getting woried it was something bad thanks again
Old Feb 24, 2008 | 06:20 PM
ddd4114's Avatar
Yeah, those are valve reliefs. They should be there.
Cho0se
Feb 24, 2020 02:59 PM
TravisCadello
17
Apr 10, 2009 11:29 PM
Chuethou_b18c5
May 1, 2006 11:51 PM
GSR4door1
Apr 24, 2004 08:02 AM
Eg6_JDM
Sep 20, 2002 06:44 AM
