Another question for the pros:
Old Feb 24, 2008 | 03:43 PM
philliedawg's Avatar
Default Another question for the pros:
I'm building a all motor LS vtec and as for my bottom end; Can i still just use my crank as is, without balancing it and knife cut and micro polish it? My LS motor ran perfect b4 i started stripping it down and start building my LS vtec. And my second question is; With me using the crank as is; I'm planning on using a CTR pulley; Would it be just fine if I balance the entire ratating assembly after the bottom end id complete?..thanks guys..
Old Feb 24, 2008 | 03:57 PM
getsome.crx's Avatar
Default Re: Another question for the pros: (philliedawg)
i'm running a LS/VTEC you can run a stock crank without all the work but you will ruin the rings faster if you are racing it alote. i have about 5000 miles on my build with a stock bottom and no problems. i was told you can usualy get 10,000 to 15,000 miles out of a motor that way before you need to replace the rings.
Old Feb 24, 2008 | 04:06 PM
Default Re: Another question for the pros: (getsome.crx)
what rings exactly are you talking about??...bearings??
PM'ed
Old Feb 25, 2008 | 03:07 AM
turboZChatch's Avatar
Without balancing the bottom end you will loose some reliability along with it not being as safe to rev up as high
For the record im no were near a pro
Modified by turboZChatch at 2:32 PM 2/25/2008
Old Feb 25, 2008 | 04:52 AM
b19coupe's Avatar
Good to see that the professionals answered your questions. Honda engineers get over 100,000 miles out of their motors, but a purpose built street motor is only good for 10-15,000? Good to know.
The stock Honda crank is very good; there is no reason that you would not have success with an untouched stock crank that is in good shape. Balancing the rotating assembly is a good idea if you plan on spinning the motor to 8,000 RPM+.
Old Feb 25, 2008 | 02:07 PM
killerpenguin21's Avatar
Default Re: (b19coupe)
search around about ctr crank pulleys too, i wouldnt use one personally. if you want a better pulley look into a fluid dampner (i believe thats the name?)
otherwise i dont see any reason stock doesnt work imho.
or you could have a stock pulley lightened and balanced into your rotating assembly, but if you do this make sure you balance in the clutch/flywheel also.
i limit my ls/vtec to 8300rpm anyway, so i kept a stock bottom end.
(disclaimer:im not a professional, b19coupe is...ive just read enough of his and other posts to kind of know what im doing lol )
Old Feb 25, 2008 | 06:35 PM
on a built bottom end you should get alot of miles out of it. but when you are running a bottom that is not designed to spin that high of rpm you will cause falilure. and most all motor setups spin untill 8,500 to 9,000.
Old Feb 25, 2008 | 06:43 PM
b19coupe's Avatar
Default Re: (getsome.crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by getsome.crx &raquo;</TD></TR><TR><TD CLASS="quote">and most all motor setups spin untill 8,500 to 9,000. </TD></TR></TABLE>
One has to wonder why spin an engine to 9,000 RPM when in most cases it is clearly unnecessary. Case in point:
Another question that comes to mind when reading the statement "most all motor setups spin untill 8,500 to 9,000", did you take a survey? Have you compiled a database of dyno sheets that validate your claim? Please educate us
Old Feb 25, 2008 | 06:52 PM
Runnerdown's Avatar
This thread makes me laugh. I really don't know what say......
Old Feb 26, 2008 | 01:45 AM
Default Re: (Runnerdown)
B19 what engine is that a dyno sheet of? Sorry if it says the setup on the page I can't read it on my phone at work
Old Feb 26, 2008 | 04:57 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">This thread makes me laugh. I really don't know what say......
Lol, yeap this is a good one.
Old Feb 26, 2008 | 07:08 AM
b19coupe's Avatar
Default Re: (turboZChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch &raquo;</TD></TR><TR><TD CLASS="quote">B19 what engine is that a dyno sheet of? </TD></TR></TABLE>
It's an LS/VTEC with a 92mm crank and an 85mm bore.
Old Feb 26, 2008 | 11:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">It's an LS/VTEC with a 92mm crank and an 85mm bore.</TD></TR></TABLE>
Nice power
Sergio Garcia
Aug 30, 2015 08:35 AM
corvetteking
Nov 15, 2010 04:46 PM
JDM97R
Jan 15, 2006 05:57 PM
RA217252
Dec 21, 2005 08:25 PM
morocco
Oct 24, 2005 08:41 PM
