91 Si Tranny Has Shaftplay.
Old Feb 24, 2008 | 02:14 PM
ZCcivicBOI's Avatar
Default 91 Si Tranny Has Shaftplay.
What title says i baught a 91 si tranny for 50$ from a guy and when i got it home i found out that the imput shaft has shaftplay, could this be because the input shaft bearing is bad??
Old Feb 24, 2008 | 02:16 PM
StorminMatt's Avatar
Default Re: 91 Si Tranny Has Shaftplay. (ZCcivicBOI)
It is actually normal for RWD transmissions to have some input shaft play. But NOT Honda transmissions. The input shaft bearing is probably fried.
Old Feb 24, 2008 | 03:14 PM
Super Chicken's Avatar
How does it move?
In and out or up and down?
In and out = no problem (within specs obviously)
up and down = problem
Old Feb 24, 2008 | 04:09 PM
ZCcivicBOI's Avatar
Default Re: 91 Si Tranny Has Shaftplay. (Super Chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">How does it move?
up and down = problem </TD></TR></TABLE>
lol it moves up and down which = problem i found a diy thread for a imput shaft bearing replacement but it was a hydro tranny im assuming its pretty much the same thing so i guess imma change it..
anyone have a idea how much a imput shaft bearing costs? can i buy it from local auto parts store?? or dealer part only?
also tranny says pl3/9000 so im assuming its a si tranny correct?
thanks for help
Old Feb 24, 2008 | 05:46 PM
white90crxhf's Avatar
if my memory serves me, i believe it's around $20. i'd just order it from http://www.hondaautomotiveparts.com that's where i got mine. i'd bet an autozone bearing will cost the same, either way you'll have to wait. You might as well get the one made my honda. You may need to replace other bearings.
there's a thread around here that helps you tell what year and model the transmission is. i was sold a 90 si transmission, what i got was an 88 si so i bought a new clutch & flywheel, not sure if the flywheel was nessesary but i bought it anyways.
Sinner
Jul 20, 2010 05:10 PM
civ_nate
Honda Civic (2001 - 2005)
May 29, 2007 02:43 PM
exx
May 12, 2004 03:36 PM
bc_psychocivic
Sep 8, 2003 03:41 PM
nsxmatt
Jun 8, 2003 07:31 PM
