itr intake cam/gsr exhaust cam combo
Old Feb 24, 2008 | 01:33 PM
iknited1's Avatar
Default itr intake cam/gsr exhaust cam combo
i see alot of people using itr intake camshaft and gsr exhaust camshaft. Is there a reason for this? I hear that the gsr exhaust camshaft and the itr exhaust cam have the same specs. Anybody with good info please chime in. Thanks
im putting a stock b16 head on my stock ls block, thats why im asking this question.
Old Feb 24, 2008 | 02:41 PM
Fat Chick Magnet's Avatar
They're good cams if you don't want to upgrade dual valve springs/retainers and keep revs at stock limit. They make pretty nice power for OEM replacement.
Old Feb 24, 2008 | 03:07 PM
iknited1's Avatar
Default Re: (Fat Chick Magnet)
thanks for the fast reply. But why do people run 1 itr intake cam and 1 gsr exh cam. Does that combination make more power than running itr cams on intake and exhaust?
Old Feb 24, 2008 | 03:48 PM
all-mtr-teg's Avatar
Default Re: (iknited1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iknited1 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the fast reply. But why do people run 1 itr intake cam and 1 gsr exh cam. Does that combination make more power than running itr cams on intake and exhaust? </TD></TR></TABLE>
They run 1 intake and 1 exhaust cam cause they can't run 2. JK, its cause the ITR and GSR exhaust cams aren't that different. The ITR intake cam though is much more aggressive than the GSR intake cam
Old Feb 24, 2008 | 03:58 PM
iknited1's Avatar
Default Re: (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">
They run 1 intake and 1 exhaust cam cause they can't run 2. JK, its cause the ITR and GSR exhaust cams aren't that different. The ITR intake cam though is much more aggressive than the GSR intake cam</TD></TR></TABLE>
thats what i thought it was. Thanks
Old Feb 24, 2008 | 04:57 PM
electron_si's Avatar
thats what i thought it was. Thanks</TD></TR></TABLE>
also, most people can pick up a gsr exhuast cam for free/dirt cheap and finding a used/cheap ctr/itr intake came is fairly easy.
So that puts you in a set of cams for under $200 that you don't have to upgrade valvetrain.
I bought a brand new ctr intake cam still in plastic for $140 locall and got my buddys gsr ex. cam for free
Old Feb 24, 2008 | 05:28 PM
ghostskinner's Avatar
Default Re: (electron_si)
itr and gsr exhaust cam arent the same the itr exhaust cam has more lift and duration when you have both you will make more power than if you only had the itr intake cam
Old Feb 24, 2008 | 09:24 PM
socal3gsr's Avatar
What's the cheapest place online to buy an itr intake cam?
Old Feb 24, 2008 | 09:38 PM
numberone's Avatar
Default Re: (socal3gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iknited1 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought it was. Thanks</TD></TR></TABLE> if they were the same everyone would have gsr cams. The reason people do this is because its a decent upgrade and they can't or don't want to spend the extra money for both intake and exhaust cams. I have the set in my lsvtec and it feels great.
NA JDM GSR
Oct 10, 2006 07:29 PM
94b16teg
Sep 8, 2006 01:26 PM
P@@RB@Y
Nov 30, 2005 03:06 PM
Vtecme92
Oct 17, 2005 01:05 PM
skunked
Dec 12, 2002 10:01 AM
