electronic problems?
Old Feb 24, 2008 | 10:38 AM
wolf95's Avatar
Default electronic problems?
I was driving in town the other day and i dont know if it matters but i'm running a donut on my 95 del sol Si because i'm waiting for my new car to come in the mail. I was getting close to a yellow light and figured i couldn't make it so i slammed on the brakes. of course the donut squealed cuz its about four sizes smaller than my rims. I'm running 18" konig rims with a stock donut Then i was sittin there waitin for it to turn green and my headlights went out, my e-brake light was still lit and my guage lights dulled down. The headlights came back on but since then my e-brake light stays on and my guage lights are still dim. Will this problem be fixed when i get the new tire put on? if not, how can i fix this? thanks
Old Feb 24, 2008 | 11:14 AM
ke98248's Avatar
Default Re: electronic problems? (wolf95)
What the fuck are you talking about?
Old Feb 24, 2008 | 11:32 AM
mrferioeg's Avatar
Old Feb 24, 2008 | 06:50 PM
wolf95's Avatar
Default Re: electronic problems? (mrferioeg)
Ever since that day, my ebrake light stays on and my guages, like, the speedometer, rpms, oil temp... the backlight on that is dimmer than it should be.
Old Feb 25, 2008 | 07:01 AM
1988_96hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wolf95 &raquo;</TD></TR><TR><TD CLASS="quote">Ever since that day, my ebrake light stays on and my guages, like, the speedometer, rpms, oil temp... the backlight on that is dimmer than it should be.</TD></TR></TABLE>
if you put the ebrake handle down and the brake light stays on, check your brake fluid level. have you checked the dimmer switch to see if thats just turned down. and back to the brake problem, do you have abs? it might have something to do with that but idk anything about abs
Old Feb 25, 2008 | 07:08 AM
mortificationrock's Avatar
Default Re: electronic problems? (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">What the fuck are you talking about?</TD></TR></TABLE>
X2
Old Feb 25, 2008 | 07:43 AM
Davus's Avatar
Default Re: electronic problems? (1988_96hb)
Oh God, I thank you for that brake fluid tip, I figured mine was caused by a short wire. Checking immediately after class!
Old Feb 25, 2008 | 02:21 PM
wolf95's Avatar
Default Re: electronic problems? (Davus)
well, i just thought the problem was just from that day. and yes, i checked my light dimmer switch. and i dont think the 95s have abs
Civiccity03
Honda Civic (2001 - 2005)
14
Dec 17, 2014 11:37 AM
xkitex
Feb 3, 2014 12:13 PM
spark66
Jan 21, 2008 02:43 PM
Samuels
Dec 14, 2007 03:45 AM
jew
Aug 30, 2005 06:08 PM
