2003 EX Transmission Fluid question.
Hello everybody,
I have a Honda Civic EX Coupe 2003 and last night i went to my mechanic to get a transmission flush. He hooked his machine up to the car and flushed out the old fluid and refilled it with the new one (generic) and then added a additive called Lube Guard.
The car has 84,480 miles on it now and previously i had only drained and refilled the transmission with HONDA Genuine ATF-Z1.
After the flush last night with the generic fluid and lube guard additive i feel that the shifting is a bit harder. I am very dissapointed with this and i dont know what to do now.
Should i take it back to him and let him drain out all the fluid and then refill it manually with the HONDA Genuine ATF-Z1? Will that be good enough to get my old transmission smoothness back?
Please help!
Thanks
Dj
Please help!
Thanks
Dj
yeah....but youre kinda at fault too bud (should always use HONDA Genuine ATF-Z1) ....either way, just stop by at honda and buy some of the fluid you do need....take it back to the dude who used the cheap **** and have him replace it....
You should never ever flush a transmission, as it'll send metal particulates back into the transmission housing instead of keeping them on the bottom where they belong.
I'd have him drain whatever he added and add in Honda ATF. I wouldn't use anything outside of Honda ATF for their transmissions as they seem to be particularly picky.
I had the generic oil drained out and refilled it with ATF-Z1.
And i still have the same problem.
What should i do?
Is it may be the timing belt needs to be replaced (84500 miles)?
Do i need to get the flush done from honda?
What should i do?
did you just do a drain and fill once? if so i recommend you do 2 or 3 more drain and refills to flush out all the generic fluid trans holds about 7 to 9 quarts. one drain and refill only removes 2 1/2 quarts. honda are very sensitive to other trans fluid other than the atf-z1.
always use ATF-Z1 honda trans fluid in a honda or acura vehicle to keep that smooth shifting.
sjala76
Mar 19, 2013 08:08 PM
joekrz
14
May 8, 2007 07:09 AM
