milkshakey oil
Old Feb 24, 2008 | 09:09 AM
thedudefromjerz's Avatar
Default milkshakey oil
I recently had a vacuum hose mixed with a coolant hose and it turned my oil milky. I corrected the problem but now my car is still smoking white smoke but it does not smell like coolant anymore it smells like somethings burning. What could it be.
Old Feb 24, 2008 | 09:26 AM
ludesrv's Avatar
You had a vacuum hose mixed with a coolant hose? Yikes.
I would take off the head and examine the damage.
Old Feb 24, 2008 | 10:35 AM
HondaHeddie's Avatar
Default Re: milkshakey oil (thedudefromjerz)
omfg
that was quite a bit of confusion.
post some pics, please
which hoses did you mix up?
this might be worthy of some addition to a sticky
oh and BTW
Change your oil now!
dont try to "burn off" the water
check your coolant as well, you may need to change that too
Old Feb 24, 2008 | 01:46 PM
BLOWNEF9's Avatar
Did you switch a vacuum hose with the hose to the overflow res? I thought I read somewhere about someone doing that and am just dumbfounded that someone could be so bright.
Edit: Turns out it was you... with the same thread posted a few days ago. Why does it take 2? https://honda-tech.com/zerothread/2232021
Modified by BLOWNEF9 at 11:58 PM 2/24/2008
Old Feb 24, 2008 | 02:29 PM
Default Re: (BLOWNEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLOWNEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Did you switch a vacuum hose with the hose to the overflow res? I thought I read somewhere about someone doing that and am just dumbfounded that someone could be so bright. </TD></TR></TABLE>
yeah
just to be sure.... the big thing in front of the engine, with the fans on it, is NOT the oil tank!
Old Feb 24, 2008 | 08:29 PM
No I didnt switch a vacuum hose with the coolant res hose. But as you know (at least I hope you do) all the coolant lines are connected somehow. I had a line running from the eacv to the vacuum hose on the back drivers side of the im.
Old Feb 25, 2008 | 07:35 AM
rifter's Avatar
Do a oil change and a complete coolant system flush and report back to us.
Old Feb 25, 2008 | 07:47 AM
SIred91's Avatar
Rainman
Default Re: (HondaHeddie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudefrom-shouldnt work on cars &raquo;</TD></TR><TR><TD CLASS="quote">
just finished a mpfi swap. I used a z6 im. I cant seem to figure it out. I have a vacuum line somehow crossed with a antifreeze line. When the car is running antifreeze is sucked from the resevoir so quick. You can hear the vacuum. Its sucking antifreeze into my motor and smoking like crazy. anybody have experience with the z6 im or have this problem b4 please let me kno.
But there is vacuum coming from my coolant resevoir hose. </TD></TR></TABLE>
This is one of the best 'I effed up my car' threads ever.....
I hope you figure it out mang!
Old Feb 25, 2008 | 12:47 PM
Default Re: (SIred91)
Thanks dude. nEWS FLASH . Flushed and refilled coolant. changed thermostat. Drained and refilled oil. Car now runs. Doesnt overheat. So far so good. and FYI i am not an expert mechanic but at least now i know every damn vacuum and coolant line in my car.
Old Feb 25, 2008 | 06:30 PM
SETI20's Avatar
Takes a man to own up to a mistake. And a kid to point out the obvious.
That coolant can get into every nook and cranny of the intake system. Can take forever to clear out completely. It'll be a bood idea to get a big can of carb cleaner. You can spray that directly into your throttle body. (take off filter stuff first).
It'll clean out the gunk. And won't smell as bad as burning coolant either.
scottyb2fast
Aug 7, 2014 10:14 PM
Solidis
May 2, 2014 03:38 PM
zdizzle
Mar 10, 2008 10:50 AM
92HB_HB
May 6, 2005 07:15 PM
LudeyKrus
Aug 3, 2004 12:38 PM
