Engine is shaking real hard i need some help
Old Feb 24, 2008 | 09:00 AM
ahmedmonasar's Avatar
Default Engine is shaking real hard i need some help
wats up all i turned on my car 2day and all of sudden is strted 2 shake real hard i think its called the gear meter but not sure with the 1-6 numbers keeps goin up and down and im not even pressing on the gas when i start 2 drive the engine stops shaking but once i stop it starts 2 shake again and the meter goes bak up and down so does any1 know the problem if so plz post up thnx
Old Feb 24, 2008 | 09:15 AM
2redstars's Avatar
i dont quite understand your post. but if the engine is shaking real bad, it could be a broke motor mount, or if its not running on all cylinders it will run really ruff and shake the motor. how does it do when your driving?
Old Feb 24, 2008 | 09:22 AM
Syndacate's Avatar
Default Re: Engine is shaking real hard i need some help (ahmedmonasar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahmedmonasar &raquo;</TD></TR><TR><TD CLASS="quote">wats up all i turned on my car 2day and all of sudden is strted 2 shake real hard i think its called the gear meter but not sure with the 1-6 numbers keeps goin up and down and im not even pressing on the gas when i start 2 drive the engine stops shaking but once i stop it starts 2 shake again and the meter goes bak up and down so does any1 know the problem if so plz post up thnx</TD></TR></TABLE>
Sounds like a vacuum leak if I'm reading this correctly.
The "gear meter" you speak of, I do believe is the tachometer. What's happening is either A) The FITV, B) the IACV, or C) There's a leak in the vacuum system - is throwing off the vacuum of your intake system, which is creating a surging idle as your car can't hold a steady idle with random air coming in.
The tachometer reads RPM (engine speed).
As it gets very low, the car starts to shake a lot as it's ready to stall out, then it kicks back up and it's fine - that's why it's revving.
Generally a simple problem, generally a pain in the *** to diagnose.
Vacuum test the intake system, a FITV or IACV problem usually just makes the idle surge, but if it's accelerating like you're giving it gas (but you're not) that's usually the sign of a vacuum leak. Vacuum pressure test the intake system, find where it's leaking, fix the leak, and it should be fine.
EDIT:
Or I could be completely wrong and the "gear meter" you speak of could be something different altogether O.o
Old Feb 24, 2008 | 09:56 AM
sql_civic's Avatar
Default Re: Engine is shaking real hard i need some help (Syndacate)
One possiblity that might explain the shaking is that a spark plug is broken and you are losing compression. You'll see the ignition wire rise up and down each time the plug fires.
sxm109
Honda Civic (2006 - 2015)
Mar 22, 2010 06:06 AM
radialsym
Transmission & Drivetrain
Nov 8, 2008 05:50 AM
HondaTeg95
Mar 28, 2006 01:54 PM
onyx00
Jan 24, 2005 03:47 PM
jiggagnome
Honda S2000
Jan 5, 2005 12:58 PM
