Steering Knuckle/spindle
Old Feb 24, 2008 | 08:59 AM
Socketman's Avatar
Default Steering Knuckle/spindle
Hi im kind of new to the whole Honda thing... I have always had Nissans and Mazdas. The problem is thats i have had two wheel bearings pressed into my steering knuckle on the passenger side. This is just in the past month and they go bad about a week later... My guess is that the actual steering knuckle is worn out and does not press in tight enough... Can i use a steering knuckle from an EF hatch? I drive a 91 DX CRX
Old Feb 24, 2008 | 03:45 PM
lilbill_ed8's Avatar
yeah man it should be the same .. i mean i haven't tried it but i am running the knuckles from an integra on my crx with out a prob and those are 2 different cars ..
btw search is your friend cuz i know i have seen this in another tread before
oh and welcome to honda-tech
Old Feb 24, 2008 | 04:26 PM
littlegrayhonda's Avatar
the da and ee are pretty much the same not to sure about hatch and
Old Feb 24, 2008 | 05:14 PM
hondacivic90zc's Avatar
Default Re: (littlegrayhonda)
yes you can use the knuckle from the hatch without a problem
Old Feb 24, 2008 | 05:22 PM
dr_latino999's Avatar
Default Re: Steering Knuckle/spindle (Socketman)
Have you replaced the actual wheel hub, the piece that is then pressed into the bearing?
Old Feb 24, 2008 | 05:35 PM
white90crxhf's Avatar
i can't imagine a knuckle wearing out, isn't it cast iron?
Old Feb 25, 2008 | 12:20 PM
alscrx's Avatar
Default Re: (white90crxhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90crxhf &raquo;</TD></TR><TR><TD CLASS="quote">i can't imagine a knuckle wearing out, isn't it cast iron?</TD></TR></TABLE>
Sure is....i mean it could get bent but not sure if that cause premature wear on the bearings.
Also, are you sure its the wheel bearings? And how are you testing this?
Also, did you have the same shop do the work both times?
gpdxtrm
13
Dec 28, 2007 08:10 PM
1phathatch
May 18, 2004 08:32 PM
filthyCREX
Feb 13, 2004 01:21 PM
YumVTEC
10
Dec 20, 2002 05:45 AM
OneThirtyEight
Jan 22, 2002 06:44 PM
