B20z2 head bolt torque specs and order?
Old Feb 23, 2008 | 10:34 PM
ivan93egreppin210's Avatar
Default B20z2 head bolt torque specs and order?
i need to know the stock head bolt specs (not arp) and order they need to be torqued. also what steps do i take to install them correct (do i need to lube the bolts?)i also need the cam cap specs and order for them as well. i looked and the best i could find was 24-26 at first then 61 to finish. is this correct? i know i saw a pic of the order for the head bolts but i cant find it. what brand of lube do i get at autozone?lol I,VE SEARCHED SINCE 7:00 PM YESTERDAY)
Old Feb 24, 2008 | 08:07 AM
Default Re: B20z2 head bolt torque specs and order? (ivan93egreppin210)
i found it..... 29 lbs-51lbs-72lbs
[QUOTE=89s1]
and for the caps.......
For the cam cap/holder bolts...
12mm: 20 ft/lbs
10mm: 7.8 ft/lbs
im confused. is it like this for the cams
(5)(13)(9)(1)(7)(11)(3)
(6)(14)(10)(2)(8)(12)(4)
or like this.....
(13)(09)(5)(1)(3)(7)(11)
(14)(10)(6)(2)(4)(8)(12)
please help. i will continue to search
Modified by ivan93egreppin210 at 11:33 AM 2/24/2008
Old Feb 25, 2008 | 04:46 PM
can someone please help with the cap torque order? i tried downloading the helms at hondahookup but it has errors. im ordering a helms online but i cant wait till it gets here. please help. NOTE TO FELLOW ENGINE BUILDING NOOBS.....BUY A HELMS IF YOU INTEND TO BUILD A MOTOR IM PAYING THE PRICE.
Old Apr 11, 2008 | 03:51 PM
michael_c's Avatar
bump
polishedturd
May 29, 2009 05:41 AM
ivan93egreppin210
Feb 24, 2008 08:30 AM
GsrIntegra789
Sep 28, 2006 07:26 AM
tuan...
Nov 20, 2004 01:37 PM
xXx Justin xXx
Apr 1, 2004 07:20 PM
