Transmission Leaking?
Old Feb 23, 2008 | 08:42 PM
bopbop93030's Avatar
Default Transmission Leaking?
I just got underneath my 95 Accord and theres a leak under the transmission, I do not think its leak ATF coz. the color is brownish like oil any idea where might this be coming from?
The oil pan is on the opposite side so I do not think thats the culprit. Is it possible for the transmission to leak oil or is it inside the transmission like seals or crankshaft seal or something?
Thanks in advance.
Old Feb 23, 2008 | 08:53 PM
2accrds's Avatar
Default Re: Transmission Leaking? (bopbop93030)
It might be the rear main, or something up top is seeping down. If your ATF is old and dirty it might look like engine oil.
Old Feb 23, 2008 | 09:26 PM
TheMuffinMan's Avatar
He knows where you live!
Really old tranny fluid can look black.
Ask me how I know.
It also is the foulest smelling substance ever.
Old Feb 23, 2008 | 10:56 PM
Default Re: (TheMuffinMan)
The thing is I just changed my ATF a month ago and the dip stick is reddish color fluid will post pictures as soon this rain stops.
Old Feb 23, 2008 | 11:49 PM
Jmumblez2001's Avatar
Default Re: (bopbop93030)
i have a five speed tranny, and i noticed a leak between the tranny and the oil pan, and my guess it's the rear main seal anywy mine is a slow leak hope you have the same issue as i do.
Old Feb 23, 2008 | 11:53 PM
Default Re: (Jmumblez2001)
rear main seal?
Is that a common leak?
Old Feb 24, 2008 | 12:06 AM
not usually, but you figure after so many miles on your car seals wear out, rear main seal included. Replacing the rear main seal is a BITCH tranny needs to be removed, in my opinion if it's not dripping the quart leave it be. GL
Old Feb 24, 2008 | 07:13 AM
billyrusa's Avatar
If the leaked oil is on the side close to oil pan, that should be oil pan gasket leak. If the leaked oil is on the side close to wheel, check if the oil come from top. Most likely it is distributor o-ring leak. These were what happened to my car.
Blazinmiller
Aug 31, 2010 08:14 PM
TOO MUCH TORQUE
Jul 13, 2008 12:00 PM
TylerC
Aug 8, 2005 08:13 AM
danteisme
Jun 1, 2005 05:31 PM
krshultz
Feb 4, 2002 05:07 PM
