confused...help..
Old Feb 23, 2008 | 08:00 PM
honda_ek9's Avatar
Default rebuild ITR or new motor
is it worth rebuilding a JDM 96 ITR spec...or should buying a new motor...or buy another JDM ITR motor...and sell the blown ITR...
Modified by honda_ek9 at 8:33 AM 2/24/2008
Modified by honda_ek9 at 11:19 AM 2/24/2008
Old Feb 23, 2008 | 08:25 PM
BlueIntegraBoy's Avatar
Default Re: confused...help.. (honda_ek9)
Depends. Is it just a rebuild or blown motor? What are your plans for the motor?
Old Feb 24, 2008 | 07:33 AM
honda_ek9's Avatar
Default Re: confused...help.. (BlueIntegraBoy)
to just get it back to running conditions...but trying to get 200whp....
Old Feb 24, 2008 | 07:15 PM
honda_ek9's Avatar
Default Re: rebuild ITR or new motor (honda_ek9)
anyone...help...
Old Feb 24, 2008 | 08:08 PM
92TypeR's Avatar
FSAE
You havn't told us what is wrong in the first place. Hard to answer a question when all the necessary info hasn't been revealed.
If you are simply throwing a new set of rings and bearings in an old motor, that shouldn't take more than a weekend if it is your first attempt, and will give you a good fresh start.
Old Feb 26, 2008 | 07:40 AM
honda_ek9's Avatar
Default Re: rebuild ITR or new motor (92TypeR)
well i blew motor...so i found out that i have a whole in one of my piston with a smash spark plug from that cylinder...might have a bent valve but not sure yet...havent taken out the motor yet...still in the process...been alittle busy with school and work...but yea...thats all i know for know...
Old Feb 26, 2008 | 11:08 AM
CW-ITR's Avatar
Sounds like a re-buildable one. Pull it apart and find out.
Old Feb 26, 2008 | 12:35 PM
citrus3000psi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">anyone...help...</TD></TR></TABLE>
I would do whatevers cheaper. I would rebuild the motor myself. However I'm not sure of your mechanical skills so this may not be cheaper than buying whole new motor.
Old Feb 26, 2008 | 01:03 PM
sheekdude's Avatar
Default Re: rebuild ITR or new motor (CW-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a re-buildable one. Pull it apart and find out.</TD></TR></TABLE>
X2. Sounds like new valves, and new pistons... but if you're not mechanically inclined then
Old Feb 26, 2008 | 01:14 PM
Fat Chick Magnet's Avatar
I would probably purchase a ITR long block and just use my transmission off the USDM blown motor you have and swap everything over to that. Most of those JDM motors are pretty healthy depending on where you purchase it from.
http://www.hmotorsonline.com
Old Feb 27, 2008 | 04:15 AM
honda_ek9's Avatar
Default Re: (Fat Chick Magnet)
yea thats what i was thinking about....but first im going to take apart the motor and see wassup....if its just knew pistons and valves then sure...but if its more then buying a whole new motor then im goin to go with the new motor ITR longblock....
Benefitx
Mar 3, 2008 10:09 AM
spoonhatchblack
Oct 5, 2007 08:58 PM
kaj
May 11, 2007 09:33 PM
kaj
Apr 18, 2007 09:32 PM
