obd1 b16a gsr motor swap question
alright guys i need your help.....im putting a 93 obd1 b16a1 (xsi) motor into my 92 civic hatch. it came with the whole engine wiring harness with a p61 ecu. just picked up a s80 97 gsr hydro tranny and mounts....
what else do i need to make this swap work in my car....like wat axles do i use?
does the 90-93 or 94-01 axle work?
do i need to a jumper harness to make the ecu work?
do i need to pick up the shift linkage from a 94-01 integra?
also can i put a 94-01 integra ls/gsr stock exhaust fit on my hatch?
any help would be greatly appreciated, thank you
Modified by animoEG at 7:53 AM 2/24/2008
wait u kind of confused me. gsr b16a ? gsr is either b17 or b18c.
anyways. u will need 94-01 integra axles and rear t bracket and shift linkage and integra exhaust wont be a direct bolt on to eg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by animoEG »</TD></TR><TR><TD CLASS="quote">my bad.....its the late model b16a1 that came with the cable tranny Xsi motor...thanx for the correction</TD></TR></TABLE>
with cable tranny.then it is a obd0 b16a, u will need a cable tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">wait u kind of confused me. gsr b16a ? gsr is either b17 or b18c.
anyways. u will need 94-01 integra axles and rear t bracket and shift linkage and integra exhaust wont be a direct bolt on to eg.</TD></TR></TABLE>
he meant he had b16 w/ gsr tranny! You can use ur gsr tranny since its hydro n your car is hydro, but since its obd0 the halfshaft is for a cable. for that you just buy the 90-93 integra axles. u can use any b series shift linkage. i have no clue bout ur ecu. if it plugs up then it'll work, but ur harness wont. just plug it in n wire vtec. the integra exhausts r too long for a hatch.
hope that helps.
hope that helps.
the guy i bought the motor from had it in his DA with a ys1 cable tranny but i didnt take the tranny cause i figured i would need a 94-01 hydro tranny to fit in my car.
do i need to buy another half shaft or the one the came with the motor work?
Do you people read things before you post? It's an OBD1 B16A, not OBD0. Just because it has a cable transmission doesn't mean it has to be OBD0. Are '92-'93 USDM Integras OBD0? No, so why would the JDM or EDM ones be?
ok...so the 94-01 axles will work right?
how bout the mid-shaft...do i need to buy a 94-01 also and will i need to buy jumper harness for the p61 to work on my civic?
thanks for the help
thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon »</TD></TR><TR><TD CLASS="quote">Do you people read things before you post? It's an OBD1 B16A, not OBD0. Just because it has a cable transmission doesn't mean it has to be OBD0. Are '92-'93 USDM Integras OBD0? No, so why would the JDM or EDM ones be?</TD></TR></TABLE>
ok so ur obd1. just plug up the motor in ur car and wire vtec. u dont neccesarily need to change halfshalfs. just use the 90-93 integra axles. you wont have a problem.
