Fuel pump / relay issue. Help please!
Old Feb 23, 2008 | 07:36 PM
Arch-Angel's Avatar
Default Fuel pump / relay issue. Help please!
My 92 H23 Prelude doesn't seem to be getting any fuel to the cylinders.
Could be a blockage, but I can't hear the fule pump starting up when the ingnition is turned on.
Before I look at replacing the fuel pump, I want to check the fuse/relay!
BUT WHERE IS IT??
I kinda figured it would be with the main relay, but can't find any diagrams on the interwebz...
Old Feb 23, 2008 | 08:13 PM
Arch-Angel's Avatar
Default Re: Fuel pump / relay issue. Help please! (Arch-Angel)
Even just which wire (from the main relay) goes to the fuel pump...
I'll try cutting it and bypassing the relay.
dre2day's Avatar
Check under the hood where the other fuses are, thats the only place I can think of where the fuse would be
Old Feb 23, 2008 | 10:25 PM
Arch-Angel's Avatar
Yep, thats where i found the main relay, cheers!
In case anyone else searches for information, it's the YELLOW WIRE.
(I worked it out by process of elimination- cut them all, and reattached one by one.)
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
Domnificent
Jul 11, 2010 10:29 AM
YodajdmEK4
Oct 3, 2005 09:24 AM
rudeness
Sep 12, 2005 07:57 PM
JaHnAbOi
Oct 4, 2004 10:39 PM
