Idle problem
Old Feb 23, 2008 | 02:25 PM
duscar's Avatar
Default Idle problem
Just went and test drove a 98 GSR. Drove fine but when you come to stop or push in the clutch, the RPMs sit there for a couple seconds and then drop down to 1500 where it idles. Im assuming the idle should be at around 800 or so. Any idea what the problem could be?
Thanks in advanced
Old Feb 23, 2008 | 02:42 PM
khurrum's Avatar
possible exhaust leak or vacuum hoses are not connected properly. check header + intake manifold
Old Feb 23, 2008 | 03:02 PM
duscar's Avatar
Default Re: Idle problem (duscar)
anyone else have any idea?
Old Feb 23, 2008 | 05:23 PM
duscar's Avatar
bump
Old Feb 24, 2008 | 10:31 AM
duscar's Avatar
anyone?
Old Feb 24, 2008 | 02:30 PM
duscar's Avatar
Id like to figure out what the problem is before i pick this up
Old Feb 24, 2008 | 02:40 PM
gsilnc's Avatar
check the coolant levels
Old Feb 24, 2008 | 02:42 PM
duscar's Avatar
Default Re: Idle problem (gsilnc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsilnc &raquo;</TD></TR><TR><TD CLASS="quote">check the coolant levels</TD></TR></TABLE>
i dont think coolant levels would cause the idle to be too high
Old Feb 24, 2008 | 02:48 PM
gsilnc's Avatar
oh but it can,
just check it
low coolant can cause it to idle high and rev up and down.
another suggestion would be to check the IAC
Old Feb 24, 2008 | 02:57 PM
duscar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsilnc &raquo;</TD></TR><TR><TD CLASS="quote">oh but it can,
just check it
another suggestion would be to check the IAC</TD></TR></TABLE>
where exactly is the IAC and what do i need to check on it? Ill be taking another look at it on tuesday before i decide to pick it up
Old Feb 24, 2008 | 06:26 PM
duscar's Avatar
come on guys
Old Feb 24, 2008 | 07:26 PM
infamouskillas's Avatar
dude try cleaning ur iacv (idle air control valve)...basically its mounted on ur intake manifold behind it by 2 bolts...take it off and unplug the 3 hoses i think and rinse brake cleaner through it...let it sit out and dry for 15 minutes then put it back on and connect everything back....make sure the engine has been off for the past 2 hours or so before startin this project...
http://www.team-integra.net/se...=1174
- this should answer your iacv questions and hopefully ur idling problems...good luck and let me know how it goes
Old Feb 25, 2008 | 05:33 AM
gsilnc's Avatar
Default Re: Idle problem (infamouskillas)
yes and afterward if the problem persists then simply try adjusting the iac valvle left or right.
Old Feb 25, 2008 | 07:26 AM
duscar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamouskillas &raquo;</TD></TR><TR><TD CLASS="quote">dude try cleaning ur iacv (idle air control valve)...basically its mounted on ur intake manifold behind it by 2 bolts...take it off and unplug the 3 hoses i think and rinse brake cleaner through it...let it sit out and dry for 15 minutes then put it back on and connect everything back....make sure the engine has been off for the past 2 hours or so before startin this project...
- this should answer your iacv questions and hopefully ur idling problems...good luck and let me know how it goes </TD></TR></TABLE>
Thanks, if i pick it up ill be trying that first
Old Feb 25, 2008 | 09:18 AM
blackep925's Avatar
x2.. on the iacv
Old Feb 25, 2008 | 02:24 PM
street_bliss's Avatar
agree with iacv, also could very well be vaccum leak of some kind. If it is getting air from anywhere other than throttle plate, it will idle high. places to check will be intake mani gasket, tb gasket, all vaccum lines and hoses connected to manifold. An easy way to check is spray carb cleaner on all suspected areas, if its leaking the car will suck the carb cleaner in and you will notice a change in RPM;s
Force1stiptopped
Mar 24, 2008 04:17 PM
96hatch87
Aug 25, 2007 03:06 PM
aj_zo
Mar 14, 2007 03:05 PM
dosJDM
17
Mar 27, 2005 10:08 AM
94sohcEx
Sep 23, 2004 12:25 PM
