Any DOHC's from this era???
Old Feb 23, 2008 | 10:41 AM
coltsrock's Avatar
Default Any DOHC's from this era???
Is the only way to get a DOHC engine, besides a swap, to get a newer civic other than the Eg/Ek??? Because i havent noticed any DOHC's in the D series, so i assume i have to go B series or even K series right?
Old Feb 23, 2008 | 10:47 AM
Frickr's Avatar
Default Re: Any DOHC's from this era??? (coltsrock)
wait what are you asking?? are you asking if any civics in the US come with a DOHC D? or asking what civics come with a DOHC? or asking whats available for a swap?
Old Feb 23, 2008 | 10:48 AM
slowB20ej8's Avatar
yup pretty much gotta go b series or higher, h-series k-series no d series DOHC
Archidictus's Avatar
Unceasing Measure
Stateside, B, H and K-series are your DOHC possibilities. In Japan and the Euro markets, there's an F20 that's DOHC and a non-VTEC DOHC ZC motor as well, but if you're looking to purchase a car that comes with two cams stock, you'll need either an EM1 "EK" Si or something newer.
Old Feb 23, 2008 | 10:53 AM
coltsrock's Avatar
Default Re: Any DOHC's from this era??? (Archidictus)
uggh, si's are hard to find, is there any other options?? I have 2 years to get my car so the newest it could be would probably be 05' but how much Hp could i get out of a SOHC ? If i used a Y7 with a Y8 head and maybe turbo'd it?
Old Feb 23, 2008 | 11:03 AM
Frickr's Avatar
as archidictus said, em1's are the only DOHC civic stateside. preludes come with the H22, and are easy to find. if you do find an SI chances are you will be paying for them. the best bet would be to get an EX or something compairable, and do a swap. and turbo D's can put down some numbers. just be sure to upgrade the bottom end if you want to lay some high numbers.
really you have to ask yourself, what do you want to do with the car, and what are your goals
Old Feb 23, 2008 | 11:05 AM
smileycvc's Avatar
You know you can just buy a motor right?
http://www.hmotorsonline.com is probably your best bet. Either that or if you dont have the car yet, buy a Honda that already has a swap just be sure to check over everything to make sure its ok.
Nevermind I see that you posted without a swap. Your going to have to get an integra or something if you want a dual cam or an si.
Old Feb 23, 2008 | 11:07 AM
KDL323's Avatar
Boost the D series and Spank the B SERIES haha!
Old Feb 23, 2008 | 11:15 AM
DOHChatchGUY's Avatar
Default Re: Any DOHC's from this era??? (smileycvc)
the DEL SOL VTEC and the 02+ CIVIC SI all came with DOHC VTEC/iVTEC ENGINES. also, the 1st gen integra comes with a DOHC <U>D</U> 16. just get a regular (sohc) civic and get a B swap or turbo the stock D. either way you'll have a fun car.
Old Feb 23, 2008 | 01:24 PM
smileycvc's Avatar
Default Re: Any DOHC's from this era??? (DOHChatchGUY)
I thought the first gen integra came with that D16 dual cam but couldnt remember.
Old Feb 23, 2008 | 01:28 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coltsrock &raquo;</TD></TR><TR><TD CLASS="quote">uggh, si's are hard to find, is there any other options?? I have 2 years to get my car so the newest it could be would probably be 05' but how much Hp could i get out of a SOHC ? If i used a Y7 with a Y8 head and maybe turbo'd it?</TD></TR></TABLE>
I think you feel too low of the D series.
I wouldn't go with a Y series to boost b/c quite simply they suck, IMO. I especially wouldn't go for a hybrid engine setup.
Use a full Y8 or depending on emissions a Z6 (which will hold it better) should be all you need. If you need more power you can build them up to 450hp for less than a K swap (which isn't saying much, but it's not expensive to basic build a D so it can hold more power w/o a higher redline).
Old Feb 23, 2008 | 07:53 PM
coltsrock's Avatar
Default Re: Any DOHC's from this era??? (Syndacate)
well it would be a daily driver with maybe some track on the weekends. What could i expect out of a NA Y7??? In a civic Dx (h-back)?
Old Feb 23, 2008 | 09:44 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coltsrock &raquo;</TD></TR><TR><TD CLASS="quote">What could i expect out of a NA Y7??? In a civic Dx (h-back)?</TD></TR></TABLE>
Not very much... at all. Maybe 90 hp to the wheels stock. And at that point you gotta ask yourself: is the money you spend to upgrade that motor worth it? Just start higher to begin with.
Old Feb 24, 2008 | 12:09 PM
coltsrock's Avatar
what about with bolt ons?? Like a full cat-back system, air intake, mini me swap(ported, polished head) new cams and maybe nitrous?
Old Feb 24, 2008 | 12:19 PM
OMGWTFBBQ!'s Avatar
with full bolt ons you might see like 95 to the wheels, plus whatever shot of nitrous you use.
Old Feb 24, 2008 | 12:26 PM
shadohconspiracy's Avatar
single cams don't react well to bolt ons. almost useless.
Old Feb 24, 2008 | 12:35 PM
coltsrock's Avatar
so would a a newer integra be better???
Old Feb 24, 2008 | 01:56 PM
OMGWTFBBQ!'s Avatar
Default Re: (coltsrock)
Just do a swap. Whats wrong with swaps? B series + EK = win.
Old Feb 24, 2008 | 06:09 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coltsrock &raquo;</TD></TR><TR><TD CLASS="quote">what about with bolt ons?? Like a full cat-back system, air intake, mini me swap(ported, polished head) new cams and maybe nitrous?</TD></TR></TABLE>
$$ cost of bolt-ons &gt; $$ cost of swap
performance of D with bolt-ons &lt;&lt; performance of B* stock
*I gotta say B18C actually. B16A/B18B/B20Z is so-so stock.
Old Feb 26, 2008 | 12:44 PM
coltsrock's Avatar
Default Re: (Blk00EJ8)
so a GSR would probably have a lot less hasle and everything to get the B18C
Old Feb 26, 2008 | 12:53 PM
instrument's Avatar
what is the point to this post?
are you 14 looking forward to getting your license?
Old Feb 26, 2008 | 01:04 PM
Malakai's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">what is the point to this post?
are you 14 looking forward to getting your license?</TD></TR></TABLE>
Sounds like it. Kid said he was getting his car in 2 years.
Old Feb 26, 2008 | 02:06 PM
instrument's Avatar
yeah, or maybe he's getting released....
purplerain11
Mar 7, 2013 03:42 AM
Lovin_My_E.G[G]
12
Jun 23, 2009 05:29 AM
xKAMILxEK
Jun 22, 2009 08:03 AM
marisc57
Nov 13, 2006 08:56 PM
HatchKid12
Feb 22, 2005 06:21 PM
