no heat in my civic 97
Old Feb 23, 2008 | 09:52 AM
thiscivicuser's Avatar
Default no heat in my civic 97
do i hve to change the heater core? can sum1 help me please.
Old Feb 23, 2008 | 09:56 AM
jr000's Avatar
Default Re: no heat in my civic 97 (thiscivicuser)
check your thermostat...may be stuck
Old Feb 23, 2008 | 03:09 PM
Default Re: no heat in my civic 97 (jr000)
the thermal stat open up but can't it be something eles like the heater core?
Old Feb 23, 2008 | 05:32 PM
Kista20's Avatar
if the thermostat fails it is designed to stick open so that way when it fails your car won't overheat but sometimes they will stick closed and will not allow the coolant to circulate through the block and radiator. Is your blower working at all? everytime I've seen a heater core go bad you will get a white mist comming through the vents and the vehicle overheats. But my best guess would be on the thermostat and if you decide to replace it which is only a couple bux anyways put the new one in a pot of boiling water and see if it opens up properly that way you won't have to pull everything back apart due to a faulty thermostat you just bought.
Old Feb 23, 2008 | 06:40 PM
Default Re: no heat in my civic 97 (Kista20)
the air blows but u might be rightand no mist comes in so i think ur right man... so i should just change the thermalstat right?
Old Feb 23, 2008 | 06:46 PM
o yeah and the temperature guage is in half so i know the car is not overheating. but the air blower just blow air thats it.
Old Feb 23, 2008 | 07:33 PM
Kista20's Avatar
don't know about honda but I know in older domestic vehicles sometimes something gets broke inside the heater controls when you slide the lever over for more heat that it won't open up for the heat. As always check all the fuses and make sure they are good but you said the blower works and the car is getting up to temp. One thing you could also try is to feel the hoses going from the engine to the heater core just to make sure they are getting good and hot. One more thing I just thought of if the heater core is clogged up it won't allow for the proper coolant to flow through it so it could be that and also if it is that then you would be wise to flush the whole system out because if that thing is plugged it's hard to tell the shape that what the rest of the cooling system is in.
Old Feb 23, 2008 | 07:46 PM
hmm i thought it would be the thermal stat like u said but i guess ima check if the hose gets hot...
Old Feb 23, 2008 | 07:58 PM
Blk00EJ8's Avatar
The easiest thing to do in a situation like this is to drain your coolant from the bottom of the radiator and flush water through the system when the engine is running. Allow the water to get warm and then fill further with more water. The thermostat should open after being warmed up to operating temp and then try your heater. It could have simply been caused by a blockage to your heater core. You don't have to worry about taking the thermostat out and replacing it if this works since as easy as it is, it could require some small hands. good luck.
Taylor576
Feb 23, 2016 12:46 AM
ndbdc5
Feb 17, 2011 11:35 AM
acchitt
11
Dec 16, 2010 01:09 PM
xpdude
Mar 31, 2010 11:51 AM
ITLNstallion818
Jan 19, 2005 11:31 AM
