94 gsr civic hatch how to wire in stock tack
Old Feb 23, 2008 | 08:05 AM
donvito#1's Avatar
Default 94 gsr civic hatch how to wire in stock tack
just bought this 94 gsr hatch and it had a cluster with no tack so i bought a cluster with a tack and relized the main harness didnt have the green plug right by the yellow one so i got a green plug know how do i wire it in 2 the harness so i can have a tack any diagrams? couldnt find a link
Old Feb 23, 2008 | 08:32 AM
A lil 2.3l action's Avatar
Default Re: 94 gsr civic hatch how to wire in stock tack (donvito#1)
there should be a blue wire with a block off connector by you firewall in the very back on the driverside corner crevice.... these cars are already pre wired for an aftermarket tach... just wire the signal wire to that
Old Feb 23, 2008 | 08:36 AM
statultra's Avatar
on the ECU theres a wire that goes from 0 - 49 choose the one marked 60
Old Feb 23, 2008 | 08:44 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donvito#1 &raquo;</TD></TR><TR><TD CLASS="quote">just bought this 94 gsr hatch and it had a cluster with no tack so i bought a cluster with a tack and relized the main harness didnt have the green plug right by the yellow one so i got a green plug know how do i wire it in 2 the harness so i can have a tack any diagrams? couldnt find a link</TD></TR></TABLE>
If you have a '92-95 Civic without a tachometer, and you bought a '92-95 Civic cluster with a tachometer, then you don't have to wire anything. I repeat: DO NOT TOUCH ANY WIRES. You just plug the new cluster in, and everything will work. The tach will function normally.
Old Feb 23, 2008 | 09:00 AM
Default Re: 94 gsr civic hatch how to wire in stock tack (Targa250R)
o i thought you were talking about an aftermarket tach... yeah, just plug it right in , you dont have to mess with any wires
Old Feb 23, 2008 | 12:05 PM
donvito#1's Avatar
Default Re: 94 gsr civic hatch how to wire in stock tack (A lil 2.3l action)
no it dont have a plug in i checked for the green plug none trust me any one got i diagram on those wires
Old Feb 23, 2008 | 12:35 PM
BlueIntegraBoy's Avatar
Green plug is for cruise control. You don't need to plug it in.
Old Feb 23, 2008 | 04:54 PM
donvito#1's Avatar
Default Re: 94 gsr civic hatch how to wire in stock tack (BlueIntegraBoy)
if that true why wasent my tach working?i pluged in everything and it still didnt work?i need help
Old Feb 23, 2008 | 06:07 PM
donvito#1's Avatar
help
Old Feb 23, 2008 | 07:55 PM
donvito#1's Avatar
so then my tach is not working anyone have a wiring diagram so i can follow the wire and see y it aint working
Old Feb 24, 2008 | 07:21 AM
donvito#1's Avatar
so i had a brainstrom when i was sleeping wat im going 2 do is by the disturber their the blue wire that is for wiring in the tack im going to have that wire jumped to the back of the plug on the cluster and see if it worksthat should work?
GnrlKll
Jun 14, 2017 08:34 PM
kseriesdreams
Dec 26, 2010 04:56 PM
donvito#1
27
Apr 30, 2008 02:35 PM
IDI2IEIAIVIS
Jan 30, 2003 08:30 PM
^Sammy]!.
Jan 9, 2003 05:03 PM
