16" drag radials
Old Feb 23, 2008 | 07:55 AM
Obama's Avatar
Default 16" drag radials
I know there are some decent street tires but none will hold 400whp, does anybody make a 16" radial similar to bfg's?
Old Feb 24, 2008 | 10:22 AM
R.A.T.'s Avatar
Default Re: 16" drag radials (mundane)
Would like to know as well!
Old Feb 25, 2008 | 07:29 AM
R.A.T.'s Avatar
Default Re: 16" drag radials (R.A.T.)
bump
Old Feb 25, 2008 | 09:53 AM
H22Ej1's Avatar
Shenanigans
the bfg gforce r1 comes in 205 55 16 and 225 50 16
but the t/a drag radial only comes in a 255 50 16
Old Feb 25, 2008 | 07:34 PM
R.A.T.'s Avatar
Default Re: 16" drag radials (H22Ej1)
what do yoiu think about the Nitto NT 555R Drag radial?? It's a 245/50/16
It should fit on a 16" by 7" wide, no??
Old Feb 25, 2008 | 07:37 PM
H22Ej1's Avatar
Shenanigans
that would fit on the rim i believe
Old Feb 25, 2008 | 08:53 PM
toyomatt84's Avatar
Sanji
That's as narrow of a wheel as you can get for that tire size.
Old Feb 25, 2008 | 08:55 PM
R.A.T.'s Avatar
Default Re: (toyomatt84)
how would that be on the car though? any rubbing...?
or other unexpected things for a daily driver?
Old Feb 25, 2008 | 09:12 PM
toyomatt84's Avatar
Sanji
Default Re: (R.A.T.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.A.T. &raquo;</TD></TR><TR><TD CLASS="quote">how would that be on the car though? any rubbing...?
or other unexpected things for a daily driver?</TD></TR></TABLE>
You never mentioned a car.
Old Feb 26, 2008 | 04:44 AM
R.A.T.'s Avatar
oh sorry! I'm in a 96 integra with a 1.7drop all around
Old Feb 26, 2008 | 06:45 AM
H22Ej1's Avatar
Shenanigans
that is roughly a 25 inch tall tire, 1.5-2 inches taller than stock. i used the tire size calculator and theres an 8.5 percent diameter difference roughly, its recomended to stay within + or - 3% but if these r for track use only u should be ok but you will have to raise your suspension up so they dont rub. if possible id stick with the bfgs 225/50/15, 1.7% diameter difference, i assume you want these for dual purpose street & drag and this size would be much more feasible and they may fit without having to raise your car
thegatekeeper14
Sep 22, 2009 06:24 PM
boostincoupe
Feb 7, 2008 01:12 PM
T3T495GSR
Dec 27, 2002 06:59 PM
T3T495GSR
Dec 24, 2002 11:25 AM
ITR41
Oct 15, 2002 08:32 PM
