weird noise in the rear
Old Feb 22, 2008 | 07:50 PM
immajackuup's Avatar
Default weird noise in the rear
First of all I wanted to know does trailing arm bushing make noise when it goes bad?
I know for the fact that my trailing arm bushing are bad because at certant speed I could feel the rear end move side to side.
The noise sound like an old hinge on a door that is some where in the rear suspension.
It only happen when I turn hard or go at an angle.
Think yall could figure out where the noise coming from?
my suspension are skunk2 coilover , agx adjustable , skunk2 rear camber.
Old Feb 22, 2008 | 09:30 PM
Default Re: weird noise in the rear (immajackuup)
no help for the noob?
Old Feb 22, 2008 | 09:43 PM
advan414's Avatar
weird noise in the rear? use lube. lol maybe could be your wheel bearings
Old Feb 22, 2008 | 09:56 PM
MidoriMiller's Avatar
Default Re: weird noise in the rear (advan_turbo_gsr)
sounds like trailing arm bushings.. mine are done too, i have a rear disk swap from an integra and the bushings seem good so im all set, but if you replace them use OEM or Mugen, stay away from polyurethane
Old Feb 22, 2008 | 10:38 PM
how about aftermarket that look like oem?
plus how hard is it to a rear disk swap?
i wonder is bleeding it is a bitch to do.
Old Feb 22, 2008 | 10:59 PM
http://www.rockauto.com/catalog/raframecatalog.php
gonna buy the 20 one
danno33
12
Aug 30, 2009 07:19 AM
danno33
Suspension & Brakes
Aug 24, 2009 05:16 PM
craigaria
Jul 8, 2008 07:09 PM
immajackuup
12
Aug 14, 2007 10:20 AM
cheezthis
May 4, 2005 10:50 AM
