Injector problem
Old Feb 22, 2008 | 06:45 PM
zcmotor's Avatar
Default Injector problem
Why when i plug the injector on #1 it starts throwing gas thru the headers and makes lot of white smoke.
When i take off the injector it stops?
Right now the car is fine with the injector pluged in and no check engine but feals like its staling when i accelerate
A Mechanic said it could be my ecu but im not sure. Anyone Know what's going on here ?
Modified by zcmotor at 11:00 AM 2/23/2008
Old Feb 23, 2008 | 10:06 AM
zcmotor's Avatar
Anyone ?
Old Feb 23, 2008 | 10:09 AM
zccr-xsi's Avatar
well considering it isnt throwing a code is must an easy fix.have u tried switching that injector out with a good one?i suppose this is a dohc zc motor?
Old Feb 23, 2008 | 10:36 AM
zcmotor's Avatar
Default Re: (zccr-xsi)
i have the single cam zc. well it gives me code 16 and i switched one good injector to the one that's bad and it still did the same thing.
Old Feb 23, 2008 | 11:26 AM
zccr-xsi's Avatar
did u do any wiring ?like converting to to mpfi?
Old Feb 23, 2008 | 11:31 AM
Allday07's Avatar
code 16, yes means injectors..
mostly its your main relay
Old Feb 23, 2008 | 12:40 PM
zcmotor's Avatar
No i got i had the fuel injection.never messed with any wiring.
well today i changed the IACV and it was working good after like 20 mins of driving all of sudden the car wont rev over 3000 RPM.
the only code im getting is 14
any ideas what's causing this ?
Old Feb 23, 2008 | 02:57 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (zcmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcmotor &raquo;</TD></TR><TR><TD CLASS="quote">No i got i had the fuel injection.never messed with any wiring.
any ideas what's causing this ?</TD></TR></TABLE>
its the IACV.. thats what code 14 is for...
Old Feb 24, 2008 | 02:00 AM
zcmotor's Avatar
alright well all my codes are clear now and problem fixed. I didnt realize the plug wasnt hooked up to the IACV that was causing my car not rev over 3000RPM,
Thanks all for the help
lsvSwagg
Jan 29, 2013 07:46 AM
Red_ED8
Jul 15, 2010 11:19 AM
Magick211
Oct 14, 2003 03:13 AM
BIG RICH
Jul 7, 2003 11:00 AM
4ghatch
Jan 16, 2003 02:33 PM
