Winding noise coming from engine bay......... Please Help
Old Feb 22, 2008 | 06:35 PM
meandino's Avatar
Default Winding noise coming from engine bay......... Please Help
I tried to find another thread to bump or to look off of. No luck.
Here is what happened...
After work today I was driving home, and I heard a winding noise coming from about the middle of my engine bay. When I speed up it gets louder. When I slow down it gets softer. I push the clutch in, but it doesn't effect the noise. I pulled over to check it out, but didn't hear anything. There was a little bit of the CV axle fluid on the middle of the firewall -- driver side. I checked the boot and it's not torn, so there probably is a leak somewhere.
I started to drive some more. The noise sounded really bad with the acceleration, so I pulled over and shut the car off and looked in the engine bay. I noticed some snow on the passenger lower arm in the bay. I brushed it off and made sure my axles were fine. Then I started driving once more.
There was no more noise this last time. But I know that it didn't fix itself. I don't have anything to look for anymore and need to know what it could have been, so I can fix it before it comes back. What should I do?
I let my car warm up every time before I drive it, so the problem wouldn't be a cold engine, would it?
Thanks H-T
Old Feb 22, 2008 | 06:49 PM
dagle's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (meandino)
winding noise? or whining noise? if its whining noise check your brakes first
Old Feb 22, 2008 | 10:22 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (dagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">winding noise? or whining noise? if its whining noise check your brakes first </TD></TR></TABLE>
Had my brakes checked at Les Schwab's the day before actually. They said that there good.
Sounded like the noise was more from the Differential of the Transmission housing.
Old Feb 23, 2008 | 10:06 AM
meandino's Avatar
bump for help
Old Feb 23, 2008 | 10:18 AM
Acidcrakker's Avatar
Well it has to be something that moves with the engine if you push the clutch in and it still makes the noise.
Odds are its intermitten. Which is the worst of all problems IMO.
Heres a list of possibilties
1. Altnator pulley
2. P.S. Pulley
3. Crank Pulley
4. FLywheel
Your Axels wouldnt be the problem if you step on the gas in neutral and it makes the noise worse, so Anything axel related is gone.
Hope that helps
Old Feb 23, 2008 | 10:31 AM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Well it has to be something that moves with the engine if you push the clutch in and it still makes the noise.
1. Altnator pulley
2. P.S. Pulley
3. Crank Pulley
4. FLywheel
Hope that helps</TD></TR></TABLE>
Just replaced all of these but the flywheel.
Old Feb 23, 2008 | 10:36 AM
meandino's Avatar
Correction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino &raquo;</TD></TR><TR><TD CLASS="quote">When I speed up it gets louder. When I slow down it gets softer. I push the clutch in, but it doesn't effect the noise.
If I push the clutch in and step on the accelerator it doesn't get louder. Stays with the speed of the vehicle.
Old Feb 23, 2008 | 11:16 AM
Ok well then tranny or even motor should have nothing to do with it. Mabey rebuild the CV joint and see if that helps. You did say you found a leak somewhere.
Old Feb 23, 2008 | 11:19 AM
meandino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Ok well then tranny or even motor should have nothing to do with it. Mabey rebuild the CV joint and see if that helps. You did say you found a leak somewhere.</TD></TR></TABLE>
Yeah found leak on the CV Boot. Going to replace the whole axle.
But don't know if thats going to be it.
Old Feb 23, 2008 | 12:27 PM
smackdown's Avatar
dude maybe its just your intake
Old Feb 23, 2008 | 12:29 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (smackdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smackdown &raquo;</TD></TR><TR><TD CLASS="quote">dude maybe its just your intake </TD></TR></TABLE>
its all stock
Old Feb 23, 2008 | 04:18 PM
97BB6Type-SH's Avatar
was your a/c on during this entire noise? my car makes a loud whining horrible noise which is coming from the a.c compressor which means its going bad. when i accelerate it gets louder. like a bad sounding supercharger.
Old Feb 23, 2008 | 05:01 PM
gstrudler's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (97BB6Type-SH)
Can you describe the noise more? Was it a higher pitch whining noise? If so, it might be from the alternator. The snow may have been causing a grounding issue and that's why it went away when you brushed it off. This kind of noise is also RPM-sensitive, so it will get higher pitched when your rev's go up.
Old Feb 23, 2008 | 08:25 PM
dre2day's Avatar
maybe a turbo you dont know you had lol i just had tooo....
Old Feb 23, 2008 | 08:47 PM
meandino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97BB6Type-SH &raquo;</TD></TR><TR><TD CLASS="quote">was your a/c on during this entire noise? my car makes a loud whining horrible noise which is coming from the a.c compressor which means its going bad. when i accelerate it gets louder. like a bad sounding supercharger.</TD></TR></TABLE>
Well, I had turned it off and on thinking it could have been a possibility. But the noise stayed more consistent with the speed of the wheels and not the RPM's of the engine.
Old Feb 23, 2008 | 09:01 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (gstrudler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gstrudler &raquo;</TD></TR><TR><TD CLASS="quote">Can you describe the noise more? Was it a higher pitch whining noise? If so, it might be from the alternator. The snow may have been causing a grounding issue and that's why it went away when you brushed it off. This kind of noise is also RPM-sensitive, so it will get higher pitched when your rev's go up.</TD></TR></TABLE>
Well it was more of a sound of medal on medal. like the brakes but clearly came from the middle of the engine bay. It was like I could hear it well enough that I could almost see right where it was coming from. (Kinda like watching a jet in the sky. How if you look at it flying. The sound of the jet is a little behind it.) It was coming from around the diff. part of the tranny.
Old Feb 23, 2008 | 10:03 PM
bb4socal's Avatar
overtightened timing belt. moise possible coming from cam gear area
Old Feb 23, 2008 | 10:57 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (dre2day)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day &raquo;</TD></TR><TR><TD CLASS="quote">maybe a turbo you dont know you had lol i just had tooo....
Dang, very very slow car for having turbo. LOL
Old Feb 23, 2008 | 11:06 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (bb4socal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4socal &raquo;</TD></TR><TR><TD CLASS="quote">overtightened timing belt. moise possible coming from cam gear area</TD></TR></TABLE>
I don't think it would be. I'll reset it though to be sure.
Old Feb 26, 2008 | 09:13 PM
gstrudler's Avatar
Have you replaced the axle yet? If you had a tear in the boot and you had no CV grease left, that might explain the metal on metal sound. It's possible it was binding up and "unstuck" itself for a little while.
Old Feb 27, 2008 | 05:31 AM
meandino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gstrudler &raquo;</TD></TR><TR><TD CLASS="quote">Have you replaced the axle yet? If you had a tear in the boot and you had no CV grease left, that might explain the metal on metal sound. It's possible it was binding up and "unstuck" itself for a little while.</TD></TR></TABLE>
I will replace it then. I was just waiting till I get the money. There like $415 from the dealership and I only replace my parts with Honda Genuine. Thanks for your input. I believe your correct.
Old Mar 21, 2008 | 06:42 PM
nvrdone's Avatar
Im having the same problem guy... i know excatly what youre talking about it sounds like its almost coming from the gear box or something the sound it makes is similar to that of an electric car or something. i just recently had my trans rebuild and lately ive been noticing that same noise the only problem is that im not sure if that noise was there from before i had the trans rebuild i just bought this car not too long ago so im familiar with it.... did you ever figure out what was causing the sound?
Old Mar 21, 2008 | 06:47 PM
meandino's Avatar
Default Re: Winding noise coming from engine bay......... Please Help (nvrdone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvrdone &raquo;</TD></TR><TR><TD CLASS="quote">Im having the same problem guy... i know excatly what youre talking about it sounds like its almost coming from the gear box or something the sound it makes is similar to that of an electric car or something. i just recently had my trans rebuild and lately ive been noticing that same noise the only problem is that im not sure if that noise was there from before i had the trans rebuild i just bought this car not too long ago so im familiar with it.... did you ever figure out what was causing the sound? </TD></TR></TABLE>
I have not figured it out yet. The sound went away, and like 2 weeks later came back for about 4 miles then went away again.
How about yours did it go away or is it still like that? If it went away did it come back again?
Old Mar 21, 2008 | 06:49 PM
meandino's Avatar
How is your CV axles?
Old Mar 21, 2008 | 11:08 PM
socialistic's Avatar
-CV boots contain grease, not fluid.
If the noise is connected with speed of car, and not rpm at all...this eliminates 90% of possible problems...and means it's something on or around the hubs. I'd think it would be brake related or bad hub bearing. The only thing in the middle of the engine compartment directly related to movement and not rpm...is the axles or intermediate shaft.
What exactly did you find all over the firewall? Was it grease...or was it fluid? If it was fluid, it's from something else and you need to get that diagnosed and fixed immediately. If it was grease...replace CV boots or bring your axles in to a parts store as cores and get new ones.
Anyways, back to the noise. Jack up each corner of the car...1 at a time...and manually spin each wheel to test for noise or any sort of resistance when spinning.
Axles are usually only known to make 1 sound when going bad...popping when you turn. Transmission is ruled out if you can press the clutch and the noise is still there while the car is moving...no gears are engaged or moving.
I drove on axles with torn outer CV boots, NO grease left at all...for several months before replacing them due to the popping noise occurring when I turned left. Never once did I hear any grinding, whining, or anything of the sort.
